Have set up a piston to notify me when my washing machine is done by monitoring the power draw from a smart outlet that it is plugged into. However despite setting parameters that should stop it from sending notifications unless a condition is met I am getting random notifications at any given time telling me that the machine has finished.
(PUT YOUR INFO HERE)
Power draw rises above X amount and sets washer state to “running” and only when washer then drops bellow X power draw and stays this way for X period of time sets washer state to “done” and sends push notification to my phone
[image|45x37]
7/7/2021, 2:52:44 PM +42ms
+1ms ╔Received event [212 Montague].time = 1625633564058 with a delay of -16ms
+73ms ║RunTime Analysis CS > 15ms > PS > 4ms > PE > 53ms > CE
+76ms ║Runtime (42446 bytes) successfully initialized in 4ms (v0.3.110.20191009) (74ms)
+77ms ║╔Execution stage started
+90ms ║║Cancelling condition #13’s schedules…
+91ms ║║Condition #13 evaluated true (1ms)
+95ms ║║Comparison (string) Run is (string) Run = true (1ms)
+96ms ║║Condition #14 evaluated true (4ms)
+97ms ║║Cancelling condition #12’s schedules…
+98ms ║║Condition group #12 evaluated true (state changed) (9ms)
+100ms ║║Cancelling statement #15’s schedules…
+103ms ║║Executed virtual command setVariable (1ms)
+117ms ║║Executed virtual command sendPushNotification (11ms)
+120ms ║║Executed virtual command sendNotification (1ms)
+130ms ║║Condition #19 evaluated false (7ms)
+131ms ║║Condition group #18 evaluated false (state did not change) (8ms)
+133ms ║╚Execution stage complete. (57ms)
+134ms ╚Event processed successfully (134ms)
7/7/2021, 2:52:39 PM +961ms
+1ms ╔Received event [Washing machine].power = 0 with a delay of 36ms
+64ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 46ms > CE
+66ms ║Runtime (42437 bytes) successfully initialized in 4ms (v0.3.110.20191009) (65ms)
+73ms ║║Comparison (decimal) 0.0 rises_above (integer) 50 = false (1ms)
+74ms ║║Condition #2 evaluated false (4ms)
+75ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+80ms ║║Comparison (decimal) 0.0 stays_less_than (integer) 5 = true (1ms)
+82ms ║║Condition #13 evaluated false (5ms)
+83ms ║║Condition group #12 evaluated false (state did not change) (5ms)
+90ms ║║Condition #19 evaluated false (5ms)
+91ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+92ms ║╚Execution stage complete. (25ms)
+94ms ║Setting up scheduled job for Wed, Jul 7 2021 @ 2:52:44 PM AEST (in 4.004s)
+104ms ╚Event processed successfully (103ms)
7/7/2021, 2:47:43 PM +970ms
+1ms ╔Received event [Washing machine].power = 2 with a delay of 45ms
+68ms ║RunTime Analysis CS > 12ms > PS > 3ms > PE > 53ms > CE
+71ms ║Runtime (42438 bytes) successfully initialized in 3ms (v0.3.110.20191009) (68ms)
+71ms ║╔Execution stage started
+78ms ║║Comparison (decimal) 2.0 rises_above (integer) 50 = false (1ms)
+79ms ║║Condition #2 evaluated false (4ms)
+80ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+86ms ║║Comparison (decimal) 2.0 stays_less_than (integer) 5 = true (1ms)
+87ms ║║Adding a timed trigger schedule for condition 13
+89ms ║║Condition #13 evaluated false (7ms)
+90ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+99ms ║║Condition #19 evaluated false (6ms)
+100ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+101ms ║╚Execution stage complete. (30ms)
+103ms ║Setting up scheduled job for Wed, Jul 7 2021 @ 2:52:44 PM AEST (in 299.986s)
+112ms ╚Event processed successfully (112ms)
7/7/2021, 2:47:30 PM +967ms
+1ms ╔Received event [Washing machine].power = 22 with a delay of 42ms
+68ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 50ms > CE
+70ms ║Runtime (42439 bytes) successfully initialized in 4ms (v0.3.110.20191009) (69ms)
+77ms ║║Comparison (decimal) 22.0 rises_above (integer) 50 = false (1ms)
+85ms ║║Comparison (decimal) 22.0 stays_less_than (integer) 5 = false (1ms)
+87ms ║║Cancelling any timed trigger schedules for condition 13
+88ms ║║Cancelling statement #13’s schedules…
+88ms ║║Condition #13 evaluated false (6ms)
+89ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+97ms ║║Condition #19 evaluated false (6ms)
+98ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+99ms ║╚Execution stage complete. (28ms)
+100ms ╚Event processed successfully (100ms)
7/7/2021, 2:47:20 PM +995ms
+2ms ╔Received event [Washing machine].power = 31 with a delay of 64ms
+81ms ║RunTime Analysis CS > 24ms > PS > 5ms > PE > 51ms > CE
+83ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (80ms)
+90ms ║║Comparison (decimal) 31.0 rises_above (integer) 50 = false (1ms)
+92ms ║║Condition #2 evaluated false (3ms)
+92ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+98ms ║║Comparison (decimal) 31.0 stays_less_than (integer) 5 = false (1ms)
+100ms ║║Cancelling any timed trigger schedules for condition 13
+100ms ║║Cancelling statement #13’s schedules…
+101ms ║║Condition #13 evaluated false (7ms)
+102ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+110ms ║║Condition #19 evaluated false (5ms)
+111ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+112ms ║╚Execution stage complete. (28ms)
+113ms ╚Event processed successfully (113ms)
7/7/2021, 2:47:07 PM +971ms
+1ms ╔Received event [Washing machine].power = 43 with a delay of 41ms
+60ms ║RunTime Analysis CS > 12ms > PS > 3ms > PE > 45ms > CE
+63ms ║Runtime (42439 bytes) successfully initialized in 3ms (v0.3.110.20191009) (60ms)
+63ms ║╔Execution stage started
+69ms ║║Comparison (decimal) 43.0 rises_above (integer) 50 = false (1ms)
+70ms ║║Condition #2 evaluated false (4ms)
+71ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+76ms ║║Comparison (decimal) 43.0 stays_less_than (integer) 5 = false (1ms)
+78ms ║║Cancelling any timed trigger schedules for condition 13
+78ms ║║Cancelling statement #13’s schedules…
+79ms ║║Condition #13 evaluated false (6ms)
+80ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+87ms ║║Condition #19 evaluated false (5ms)
+88ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+89ms ║╚Execution stage complete. (26ms)
+90ms ╚Event processed successfully (90ms)
7/7/2021, 2:47:01 PM +980ms
+1ms ╔Received event [Washing machine].power = 92 with a delay of 49ms
+66ms ║Runtime (42440 bytes) successfully initialized in 4ms (v0.3.110.20191009) (64ms)
+72ms ║║Comparison (decimal) 92.0 rises_above (integer) 50 = false (0ms)
+74ms ║║Condition #2 evaluated false (3ms)
+74ms ║║Condition group #1 evaluated false (state did not change) (4ms)
+80ms ║║Comparison (decimal) 92.0 stays_less_than (integer) 5 = false (1ms)
+81ms ║║Cancelling any timed trigger schedules for condition 13
+82ms ║║Cancelling statement #13’s schedules…
+82ms ║║Condition #13 evaluated false (6ms)
+83ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+93ms ║║Condition #19 evaluated false (8ms)
+94ms ║║Condition group #18 evaluated false (state did not change) (9ms)
+95ms ║╚Execution stage complete. (29ms)
+96ms ╚Event processed successfully (96ms)
7/7/2021, 2:46:51 PM +972ms
+1ms ╔Received event [Washing machine].power = 177 with a delay of 43ms
+125ms ║RunTime Analysis CS > 12ms > PS > 3ms > PE > 109ms > CE
+127ms ║Runtime (42443 bytes) successfully initialized in 3ms (v0.3.110.20191009) (125ms)
+128ms ║╔Execution stage started
+134ms ║║Comparison (decimal) 177.0 rises_above (integer) 50 = false (1ms)
+135ms ║║Condition #2 evaluated false (4ms)
+136ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+141ms ║║Comparison (decimal) 177.0 stays_less_than (integer) 5 = false (1ms)
+143ms ║║Cancelling any timed trigger schedules for condition 13
+144ms ║║Cancelling statement #13’s schedules…
+144ms ║║Condition #13 evaluated false (6ms)
+145ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+153ms ║║Condition #19 evaluated false (6ms)
+154ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+156ms ║╚Execution stage complete. (28ms)
+157ms ╚Event processed successfully (156ms)
7/7/2021, 2:46:42 PM +38ms
+2ms ╔Received event [Washing machine].power = 415 with a delay of 62ms
+77ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 49ms > CE
+80ms ║Runtime (42441 bytes) successfully initialized in 6ms (v0.3.110.20191009) (76ms)
+86ms ║║Comparison (decimal) 415.0 rises_above (integer) 50 = false (0ms)
+88ms ║║Condition #2 evaluated false (3ms)
+88ms ║║Condition group #1 evaluated false (state did not change) (4ms)
+94ms ║║Comparison (decimal) 415.0 stays_less_than (integer) 5 = false (1ms)
+96ms ║║Cancelling any timed trigger schedules for condition 13
+96ms ║║Cancelling statement #13’s schedules…
+97ms ║║Condition #13 evaluated false (7ms)
+98ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+107ms ║║Condition #19 evaluated false (7ms)
+108ms ║║Condition group #18 evaluated false (state did not change) (8ms)
+110ms ║╚Execution stage complete. (29ms)
+110ms ╚Event processed successfully (110ms)
7/7/2021, 2:46:28 PM +5ms
+1ms ╔Received event [Washing machine].power = 180 with a delay of 43ms
+63ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 46ms > CE
+66ms ║Runtime (42443 bytes) successfully initialized in 4ms (v0.3.110.20191009) (64ms)
+73ms ║║Comparison (decimal) 180.0 rises_above (integer) 50 = false (1ms)
+80ms ║║Comparison (decimal) 180.0 stays_less_than (integer) 5 = false (1ms)
+82ms ║║Cancelling any timed trigger schedules for condition 13
+83ms ║║Cancelling statement #13’s schedules…
+83ms ║║Condition #13 evaluated false (6ms)
+84ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+104ms ║║Condition #19 evaluated false (18ms)
+105ms ║║Condition group #18 evaluated false (state did not change) (19ms)
+107ms ║╚Execution stage complete. (39ms)
+108ms ╚Event processed successfully (107ms)
7/7/2021, 2:46:27 PM +43ms
+0ms ╔Received event [Washing machine].power = 65716 with a delay of 71ms
+66ms ║RunTime Analysis CS > 12ms > PS > 5ms > PE > 50ms > CE
+68ms ║Runtime (42443 bytes) successfully initialized in 5ms (v0.3.110.20191009) (67ms)
+69ms ║╔Execution stage started
+76ms ║║Comparison (decimal) 65716.0 rises_above (integer) 50 = false (1ms)
+77ms ║║Condition #2 evaluated false (4ms)
+78ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+84ms ║║Comparison (decimal) 65716.0 stays_less_than (integer) 5 = false (1ms)
+85ms ║║Cancelling any timed trigger schedules for condition 13
+86ms ║║Cancelling statement #13’s schedules…
+87ms ║║Condition #13 evaluated false (7ms)
+88ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+96ms ║║Condition #19 evaluated false (6ms)
+97ms ║║Condition group #18 evaluated false (state did not change) (8ms)
+98ms ║╚Execution stage complete. (29ms)
+99ms ╚Event processed successfully (100ms)
7/7/2021, 2:45:47 PM +14ms
+1ms ╔Received event [Washing machine].power = 180 with a delay of 61ms
+82ms ║RunTime Analysis CS > 23ms > PS > 4ms > PE > 54ms > CE
+84ms ║Runtime (42441 bytes) successfully initialized in 4ms (v0.3.110.20191009) (82ms)
+91ms ║║Comparison (decimal) 180.0 rises_above (integer) 50 = false (1ms)
+92ms ║║Condition #2 evaluated false (4ms)
+93ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+99ms ║║Comparison (decimal) 180.0 stays_less_than (integer) 5 = false (1ms)
+101ms ║║Cancelling statement #13’s schedules…
+102ms ║║Condition #13 evaluated false (7ms)
+103ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+111ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+113ms ║╚Execution stage complete. (27ms)
7/7/2021, 2:45:37 PM +951ms
+2ms ╔Received event [Washing machine].power = 156 with a delay of 69ms
+79ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 51ms > CE
+81ms ║Runtime (42441 bytes) successfully initialized in 6ms (v0.3.110.20191009) (78ms)
+88ms ║║Comparison (decimal) 156.0 rises_above (integer) 50 = false (1ms)
+89ms ║║Condition #2 evaluated false (4ms)
+90ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+96ms ║║Comparison (decimal) 156.0 stays_less_than (integer) 5 = false (2ms)
+97ms ║║Cancelling any timed trigger schedules for condition 13
+98ms ║║Cancelling statement #13’s schedules…
+99ms ║║Condition #13 evaluated false (7ms)
+100ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+116ms ║║Condition #19 evaluated false (14ms)
+117ms ║║Condition group #18 evaluated false (state did not change) (14ms)
+118ms ║╚Execution stage complete. (36ms)
+119ms ╚Event processed successfully (119ms)
7/7/2021, 2:45:21 PM +15ms
+1ms ╔Received event [Washing machine].power = 116 with a delay of 80ms
+78ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 49ms > CE
+80ms ║Runtime (42440 bytes) successfully initialized in 6ms (v0.3.110.20191009) (78ms)
+87ms ║║Comparison (decimal) 116.0 rises_above (integer) 50 = false (1ms)
+88ms ║║Condition #2 evaluated false (4ms)
+89ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+95ms ║║Comparison (decimal) 116.0 stays_less_than (integer) 5 = false (1ms)
+97ms ║║Cancelling statement #13’s schedules…
+98ms ║║Condition #13 evaluated false (6ms)
+98ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+108ms ║║Condition #19 evaluated false (8ms)
+109ms ║║Condition group #18 evaluated false (state did not change) (9ms)
+111ms ╚Event processed successfully (111ms)
7/7/2021, 2:45:10 PM +960ms
+0ms ╔Received event [Washing machine].power = 97 with a delay of 35ms
+61ms ║RunTime Analysis CS > 11ms > PS > 4ms > PE > 45ms > CE
+63ms ║Runtime (42439 bytes) successfully initialized in 4ms (v0.3.110.20191009) (62ms)
+64ms ║╔Execution stage started
+70ms ║║Comparison (decimal) 97.0 rises_above (integer) 50 = false (1ms)
+71ms ║║Condition #2 evaluated false (4ms)
+72ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+77ms ║║Comparison (decimal) 97.0 stays_less_than (integer) 5 = false (1ms)
+79ms ║║Cancelling any timed trigger schedules for condition 13
+79ms ║║Cancelling statement #13’s schedules…
+80ms ║║Condition #13 evaluated false (6ms)
+81ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+89ms ║║Condition #19 evaluated false (6ms)
+90ms ║║Condition group #18 evaluated false (state did not change) (8ms)
+91ms ║╚Execution stage complete. (27ms)
+92ms ╚Event processed successfully (92ms)
7/7/2021, 2:44:54 PM +987ms
+0ms ╔Received event [Washing machine].power = 80 with a delay of 35ms
+64ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 48ms > CE
+66ms ║Runtime (42438 bytes) successfully initialized in 4ms (v0.3.110.20191009) (65ms)
+72ms ║║Comparison (decimal) 80.0 rises_above (integer) 50 = false (0ms)
+74ms ║║Cancelling condition #2’s schedules…
+80ms ║║Comparison (decimal) 80.0 stays_less_than (integer) 5 = false (1ms)
+95ms ║║Condition #19 evaluated false (9ms)
+96ms ║║Condition group #18 evaluated false (state did not change) (9ms)
+97ms ║╚Execution stage complete. (30ms)
+98ms ╚Event processed successfully (98ms)
7/7/2021, 2:44:38 PM +991ms
+1ms ╔Received event [Washing machine].power = 67 with a delay of 64ms
+76ms ║RunTime Analysis CS > 22ms > PS > 5ms > PE > 49ms > CE
+78ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (76ms)
+84ms ║║Comparison (decimal) 67.0 rises_above (integer) 50 = true (0ms)
+85ms ║║Cancelling condition #2’s schedules…
+86ms ║║Condition #2 evaluated true (4ms)
+89ms ║║Comparison (string) Run is_not (string) Run = false (1ms)
+90ms ║║Condition #3 evaluated false (3ms)
+91ms ║║Condition group #1 evaluated false (state did not change) (9ms)
+96ms ║║Comparison (decimal) 67.0 stays_less_than (integer) 5 = false (1ms)
+99ms ║║Condition #13 evaluated false (6ms)
+99ms ║║Condition group #12 evaluated false (state did not change) (6ms)
+108ms ║║Condition #19 evaluated false (6ms)
+108ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+110ms ║╚Execution stage complete. (31ms)
+111ms ╚Event processed successfully (110ms)
7/7/2021, 2:44:21 PM +981ms
+1ms ╔Received event [Washing machine].power = 41 with a delay of 61ms
+83ms ║RunTime Analysis CS > 22ms > PS > 5ms > PE > 56ms > CE
+85ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (84ms)
+86ms ║╔Execution stage started
+92ms ║║Comparison (decimal) 41.0 rises_above (integer) 50 = false (1ms)
+93ms ║║Condition #2 evaluated false (4ms)
+94ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+99ms ║║Comparison (decimal) 41.0 stays_less_than (integer) 5 = false (1ms)
+101ms ║║Cancelling any timed trigger schedules for condition 13
+102ms ║║Cancelling statement #13’s schedules…
+102ms ║║Condition #13 evaluated false (6ms)
+103ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+111ms ║║Condition #19 evaluated false (6ms)
+112ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+114ms ╚Event processed successfully (115ms)
7/7/2021, 2:44:15 PM +975ms
+1ms ╔Received event [Washing machine].power = 31 with a delay of 46ms
+64ms ║RunTime Analysis CS > 12ms > PS > 3ms > PE > 48ms > CE
+66ms ║Runtime (42439 bytes) successfully initialized in 3ms (v0.3.110.20191009) (65ms)
+73ms ║║Comparison (decimal) 31.0 rises_above (integer) 50 = false (1ms)
+80ms ║║Comparison (decimal) 31.0 stays_less_than (integer) 5 = false (1ms)
+84ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+91ms ║║Condition #19 evaluated false (5ms)
+92ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+93ms ║╚Execution stage complete. (26ms)
+94ms ╚Event processed successfully (94ms)
7/7/2021, 2:43:58 PM +964ms
+0ms ╔Received event [Washing machine].power = 35 with a delay of 40ms
+63ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 47ms > CE
+65ms ║Runtime (42439 bytes) successfully initialized in 4ms (v0.3.110.20191009) (64ms)
+66ms ║╔Execution stage started
+72ms ║║Comparison (decimal) 35.0 rises_above (integer) 50 = false (0ms)
+75ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+80ms ║║Comparison (decimal) 35.0 stays_less_than (integer) 5 = false (1ms)
+92ms ║║Condition #19 evaluated false (5ms)
+92ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+94ms ║╚Execution stage complete. (28ms)
+95ms ╚Event processed successfully (95ms)
7/7/2021, 2:43:48 PM +975ms
+1ms ╔Received event [Washing machine].power = 40 with a delay of 43ms
+63ms ║RunTime Analysis CS > 12ms > PS > 5ms > PE > 46ms > CE
+66ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (65ms)
+73ms ║║Comparison (decimal) 40.0 rises_above (integer) 50 = false (1ms)
+80ms ║║Comparison (decimal) 40.0 stays_less_than (integer) 5 = false (1ms)
+92ms ║║Condition #19 evaluated false (6ms)
+93ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+94ms ║╚Execution stage complete. (27ms)
7/7/2021, 2:43:29 PM +990ms
+1ms ╔Received event [Washing machine].power = 34 with a delay of 65ms
+79ms ║RunTime Analysis CS > 22ms > PS > 6ms > PE > 52ms > CE
+82ms ║Runtime (42439 bytes) successfully initialized in 6ms (v0.3.110.20191009) (80ms)
+88ms ║║Comparison (decimal) 34.0 rises_above (integer) 50 = false (1ms)
+90ms ║║Condition #2 evaluated false (3ms)
+96ms ║║Comparison (decimal) 34.0 stays_less_than (integer) 5 = false (1ms)
+105ms ║║Condition #13 evaluated false (13ms)
+108ms ║║Condition group #12 evaluated false (state did not change) (16ms)
+115ms ║║Condition #19 evaluated false (5ms)
+116ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+117ms ║╚Execution stage complete. (35ms)
7/7/2021, 2:43:24 PM +985ms
+2ms ╔Received event [Washing machine].power = 33 with a delay of 61ms
+81ms ║RunTime Analysis CS > 25ms > PS > 5ms > PE > 51ms > CE
+84ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (81ms)
+91ms ║║Comparison (decimal) 33.0 rises_above (integer) 50 = false (1ms)
+99ms ║║Comparison (decimal) 33.0 stays_less_than (integer) 5 = false (2ms)
+113ms ║╚Execution stage complete. (29ms)
+114ms ╚Event processed successfully (114ms)
7/7/2021, 2:43:08 PM +982ms
+1ms ╔Received event [Washing machine].power = 40 with a delay of 45ms
+70ms ║RunTime Analysis CS > 12ms > PS > 4ms > PE > 54ms > CE
+73ms ║Runtime (42438 bytes) successfully initialized in 4ms (v0.3.110.20191009) (70ms)
+79ms ║║Comparison (decimal) 40.0 rises_above (integer) 50 = false (1ms)
+80ms ║║Cancelling condition #2’s schedules…
+81ms ║║Condition #2 evaluated false (4ms)
+82ms ║║Condition group #1 evaluated false (state did not change) (6ms)
+87ms ║║Comparison (decimal) 40.0 stays_less_than (integer) 5 = false (1ms)
+89ms ║║Cancelling any timed trigger schedules for condition 13
+89ms ║║Cancelling statement #13’s schedules…
+90ms ║║Condition #13 evaluated false (6ms)
+91ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+98ms ║║Condition #19 evaluated false (5ms)
+99ms ║║Condition group #18 evaluated false (state did not change) (5ms)
+100ms ║╚Execution stage complete. (27ms)
+101ms ╚Event processed successfully (101ms)
7/7/2021, 2:43:01 PM +3ms
+1ms ╔Received event [Washing machine].power = 59 with a delay of 69ms
+90ms ║RunTime Analysis CS > 21ms > PS > 5ms > PE > 63ms > CE
+92ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (90ms)
+99ms ║║Comparison (decimal) 59.0 rises_above (integer) 50 = true (1ms)
+100ms ║║Cancelling condition #2’s schedules…
+101ms ║║Condition #2 evaluated true (5ms)
+108ms ║║Comparison (string) Run is_not (string) Run = false (1ms)
+109ms ║║Condition #3 evaluated false (4ms)
+112ms ║║Condition group #1 evaluated false (state did not change) (15ms)
+122ms ║║Comparison (decimal) 59.0 stays_less_than (integer) 5 = false (1ms)
+123ms ║║Cancelling any timed trigger schedules for condition 13
+124ms ║║Cancelling statement #13’s schedules…
+125ms ║║Condition #13 evaluated false (8ms)
+125ms ║║Condition group #12 evaluated false (state did not change) (9ms)
+133ms ║║Condition #19 evaluated false (6ms)
+134ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+135ms ║╚Execution stage complete. (42ms)
7/7/2021, 2:42:18 PM +41ms
+1ms ╔Received event [Washing machine].power = 13 with a delay of 124ms
+87ms ║RunTime Analysis CS > 24ms > PS > 5ms > PE > 58ms > CE
+89ms ║Runtime (42440 bytes) successfully initialized in 5ms (v0.3.110.20191009) (87ms)
+90ms ║╔Execution stage started
+96ms ║║Comparison (decimal) 13.0 rises_above (integer) 50 = false (1ms)
+97ms ║║Condition #2 evaluated false (4ms)
+98ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+103ms ║║Comparison (decimal) 13.0 stays_less_than (integer) 5 = false (1ms)
+105ms ║║Cancelling any timed trigger schedules for condition 13
+106ms ║║Cancelling statement #13’s schedules…
+106ms ║║Condition #13 evaluated false (6ms)
+107ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+114ms ║║Condition #19 evaluated false (5ms)
+115ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+116ms ║╚Execution stage complete. (26ms)
+117ms ╚Event processed successfully (117ms)
7/7/2021, 2:42:08 PM +999ms
+1ms ╔Received event [Washing machine].power = 42 with a delay of 68ms
+77ms ║RunTime Analysis CS > 21ms > PS > 6ms > PE > 51ms > CE
+79ms ║Runtime (42439 bytes) successfully initialized in 6ms (v0.3.110.20191009) (78ms)
+86ms ║║Comparison (decimal) 42.0 rises_above (integer) 50 = false (1ms)
+87ms ║║Condition #2 evaluated false (4ms)
+88ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+93ms ║║Comparison (decimal) 42.0 stays_less_than (integer) 5 = false (1ms)
+95ms ║║Cancelling any timed trigger schedules for condition 13
+96ms ║║Condition #13 evaluated false (6ms)
+97ms ║║Condition group #12 evaluated false (state did not change) (7ms)
+104ms ║║Condition #19 evaluated false (5ms)
+105ms ║║Condition group #18 evaluated false (state did not change) (6ms)
+107ms ║╚Execution stage complete. (26ms)
+107ms ╚Event processed successfully (108ms)
7/7/2021, 2:41:46 PM +960ms
+0ms ╔Received event [Washing machine].power = 13 with a delay of 39ms
+63ms ║RunTime Analysis CS > 14ms > PS > 4ms > PE > 46ms > CE
+66ms ║Runtime (42439 bytes) successfully initialized in 4ms (v0.3.110.20191009) (64ms)
+72ms ║║Comparison (decimal) 13.0 rises_above (integer) 50 = false (1ms)
+73ms ║║Condition #2 evaluated false (3ms)
+74ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+79ms ║║Comparison (decimal) 13.0 stays_less_than (integer) 5 = false (1ms)
+81ms ║║Cancelling statement #13’s schedules…
+91ms ║║Condition group #18 evaluated false (state did not change) (7ms)
+92ms ║╚Execution stage complete. (26ms)
+93ms ╚Event processed successfully (93ms)
7/7/2021, 2:41:21 PM +978ms
+1ms ╔Received event [Washing machine].power = 14 with a delay of 62ms
+84ms ║RunTime Analysis CS > 20ms > PS > 5ms > PE > 59ms > CE
+87ms ║Runtime (42439 bytes) successfully initialized in 5ms (v0.3.110.20191009) (84ms)
+87ms ║╔Execution stage started
+93ms ║║Comparison (decimal) 14.0 rises_above (integer) 50 = false (1ms)
+95ms ║║Condition #2 evaluated false (3ms)
+95ms ║║Condition group #1 evaluated false (state did not change) (5ms)
+101ms ║║Comparison (decimal) 14.0 stays_less_than (integer) 5 = false (1ms)
+102ms ║║Cancelling any timed trigger schedules for condition 13
+103ms ║║Cancelling statement #13’s schedules…
+104ms ║║Condition #13 evaluated false (7ms)
+105ms ║║Condition group #12 evaluated false (state did not change) (8ms)
+113ms ║║Condition #19 evaluated false (6ms)
+114ms ║║Condition group #18 evaluated false (state did not change) (8ms)
+115ms ║╚Execution stage complete. (28ms)
