A piston that’s been working fine for several months has started “flooding” me with notifications now when triggered. Not always, but a couple of such times the last couple of weeks.
I expect one notification the first time the checked condition is true. I believe that is what happened originally when I tested the piston.
Today for example, when the condition on line 28 became true I received 99 notifications within a minute.
Log snapshot below shows that particular event. I think the last time it happened, I got like 45 notifications… so that number seems to vary.
Oddly, none of the garage door contacts in the higher level while loop (line 23) were open (at least not per the IDE events log) at the time the inner “if” statement inactive timeout expired, so I am not sure how the line 28 condition gating notifications even evaluated true - but it must have since the “then” statements were executed.
1/17/2019, 2:13:52 PM +107ms
+0ms ╔Received event [HayekHome].time = 1547763187384 with a delay of 44722ms
+275ms ║Runtime (41885 bytes) successfully initialized in 142ms (v0.3.109.20181207) (273ms)
+276ms ║╔Execution stage started
+317ms ║║Executed virtual command sendPushNotification (11ms)
+425ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (98ms)
+517ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (89ms)
+648ms ║║Executed virtual command sendPushNotification (13ms)
+743ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (86ms)
+837ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (91ms)
+933ms ║║Executed virtual command sendPushNotification (12ms)
+1043ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (97ms)
+1132ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (87ms)
+1213ms ║║Executed virtual command sendPushNotification (18ms)
+1333ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (111ms)
+1439ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (105ms)
+1529ms ║║Executed virtual command sendPushNotification (15ms)
+1751ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (211ms)
+1857ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (103ms)
+1937ms ║║Executed virtual command sendPushNotification (14ms)
+2063ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (111ms)
+2163ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (99ms)
+2238ms ║║Executed virtual command sendPushNotification (12ms)
+2361ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (113ms)
+2474ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (112ms)
+2547ms ║║Executed virtual command sendPushNotification (11ms)
+2623ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (66ms)
+2747ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (123ms)
+2851ms ║║Executed virtual command sendPushNotification (12ms)
+2997ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (132ms)
+3111ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (113ms)
+3190ms ║║Executed virtual command sendPushNotification (9ms)
+3299ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (99ms)
+3415ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (115ms)
+3485ms ║║Executed virtual command sendPushNotification (10ms)
+3505ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (10ms)
+3572ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (66ms)
+3656ms ║║Executed virtual command sendPushNotification (11ms)
+3676ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (10ms)
+3770ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (93ms)
+3836ms ║║Executed virtual command sendPushNotification (10ms)
+3855ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (9ms)
+3947ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (90ms)
+4016ms ║║Executed virtual command sendPushNotification (10ms)
+4036ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (10ms)
+4126ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (89ms)
+4192ms ║║Executed virtual command sendPushNotification (10ms)
+4211ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (10ms)
+4301ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (89ms)
+4368ms ║║Executed virtual command sendPushNotification (10ms)
+4387ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (11ms)
+4479ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (91ms)
+4509ms ║╚Execution stage complete. (4233ms)
+4511ms ╚Event processed successfully (4511ms)
1/17/2019, 2:13:47 PM +73ms
+1ms ╔Received event [HayekHome].time = 1547763187384 with a delay of 39689ms
+207ms ║Runtime (41885 bytes) successfully initialized in 105ms (v0.3.109.20181207) (205ms)
+209ms ║╔Execution stage started
+263ms ║║Executed virtual command sendPushNotification (9ms)
+363ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (89ms)
+460ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (93ms)
+748ms ║║Executed virtual command sendPushNotification (9ms)
+846ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (88ms)
+929ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (82ms)
+1015ms ║║Executed virtual command sendPushNotification (9ms)
+1122ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (95ms)
+1209ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (85ms)
+1286ms ║║Executed virtual command sendPushNotification (8ms)
+1386ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (90ms)
+1470ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (83ms)
+1546ms ║║Executed virtual command sendPushNotification (8ms)
+1722ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (167ms)
+1807ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (83ms)
+1884ms ║║Executed virtual command sendPushNotification (9ms)
+1991ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (97ms)
+2111ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (119ms)
+2199ms ║║Executed virtual command sendPushNotification (10ms)
+2296ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (88ms)
+2373ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (76ms)
+2448ms ║║Executed virtual command sendPushNotification (9ms)
+2533ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (76ms)
+2616ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (81ms)
+2688ms ║║Executed virtual command sendPushNotification (9ms)
+2775ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (77ms)
+2850ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (73ms)
+2924ms ║║Executed virtual command sendPushNotification (9ms)
+3014ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (80ms)
+3089ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (74ms)
+3163ms ║║Executed virtual command sendPushNotification (9ms)
+3249ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (77ms)
+3323ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (73ms)
+3394ms ║║Executed virtual command sendPushNotification (8ms)
+3483ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (80ms)
+3558ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (72ms)
+3630ms ║║Executed virtual command sendPushNotification (8ms)
+3718ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (78ms)
+3792ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (73ms)
+3864ms ║║Executed virtual command sendPushNotification (9ms)
+3973ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (100ms)
+4058ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (83ms)
+4131ms ║║Executed virtual command sendPushNotification (8ms)
+4228ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (88ms)
+4311ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (81ms)
+4380ms ║║Executed virtual command sendPushNotification (8ms)
+4470ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (80ms)
+4546ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (74ms)
+4613ms ║║Executed virtual command sendPushNotification (8ms)
+4698ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (76ms)
+4771ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (72ms)
+4839ms ║║Executed virtual command sendPushNotification (9ms)
+4924ms ║║Executed [Echo - Family Room].setVolumeSpeakAndRestore (77ms)
+5002ms ║║Executed [Echo - Media Room].setVolumeSpeakAndRestore (77ms)
+5053ms ║╚Execution stage complete. (4843ms)
+5063ms ║Setting up scheduled job for Thu, Jan 17 2019 @ 2:13:08 PM PST (in 1s), with 15 more jobs pending
+5071ms ╚Event processed successfully (5071ms)
1/17/2019, 2:13:42 PM +445ms
+1ms ╔Received event [HayekHome].time = 1547763186809 with a delay of 35635ms
+7389ms ║Piston waited at a semaphore for 7129ms
+7393ms ║Runtime (41955 bytes) successfully initialized in 7262ms (v0.3.109.20181207) (7389ms)
+7395ms ║╔Execution stage started
+7396ms ║╚Execution stage complete. (1ms)
+7412ms ║Setting up scheduled job for Thu, Jan 17 2019 @ 2:13:07 PM PST (in 1s), with 33 more jobs pending
+7422ms ╚Event processed successfully (7423ms)
