I’m trying to write a piston that if the lights are off when a door is opened, it would turn them on to 100%, and stay on if the door is open, then turn off 2 min after the door is closed. (I currently have it set to 30 sec so I am not sitting around waiting for 2 min every time I test it. If any one of the lights are already on, I do not want the piston to run. I currently have the lights turn on and off how I want if all the lights are off, however, if a light is on, it turns that light off 2 min(30 sec) after the door is shut.
If lights are already on, do not turn the lights off after the specified time.
When the lights are already on when the door is opened, they are turning off after the set time.
| +0ms | ╔Received event [Tom And Amy Home].time = 1570244758365 with a delay of -1041ms |
| +442ms | ║RunTime Analysis CS > 132ms > PS > 276ms > PE > 35ms > CE |
| +445ms | ║Runtime (39628 bytes) successfully initialized in 276ms (v0.3.10f.20190822) (444ms) |
| +446ms | ║╔Execution stage started |
| +454ms | ║║Cancelling condition #2’s schedules… |
| +461ms | ║║Cancelling condition #11’s schedules… |
| +462ms | ║║Condition #11 evaluated true (1ms) |
| +463ms | ║║Cancelling condition #8’s schedules… |
| +465ms | ║║Condition group #8 evaluated true (state changed) (5ms) |
| +467ms | ║║Cancelling statement #12’s schedules… |
| +483ms | ║║Executed physical command [Basement Love seat Lamp].off() (12ms) |
| +484ms | ║║Executed [Basement Love seat Lamp].off (14ms) |
| +497ms | ║║Executed physical command [Office Lamp].off() (11ms) |
| +498ms | ║║Executed [Office Lamp].off (13ms) |
| +500ms | ║╚Execution stage complete. (54ms) |
| +502ms | ╚Event processed successfully (501ms) |
