I’m trying to access a simplecommands Webhook to get the status of my Garage door.
when I access the URL I get this information
{“sessionId”:“89f00699-9bfa-4b10-bd2f-b72cf5aa0fdf”,“requestId”:“1ac5077f-974b-42b3-907b-e896261a0435”,“responseText”:“Your Garage Door is closed.”,“responseCode”:“SESSION_SUCCESS”,“followUpExpected”:false,“sessionComplete”:true,“json”:null,“applicationType”:“SIMPLECOMMANDS”}
I want to be able to access the value of responseText to determine if my Garage door is open or closed
(PUT YOUR INFO HERE)
It seems like the only value I get in $response after the get is a :
**4) Post a Green Snapshot of the piston![image|45x37]![image|690x372]
4/24/2021, 11:09:16 AM +32ms
+0ms ╔Received event [Home].time = 1619276957405 with a delay of -1374ms
+26ms ║RunTime Analysis CS > 13ms > PS > 4ms > PE > 10ms > CE
+29ms ║Runtime (38032 bytes) successfully initialized in 4ms (v0.3.113.20210203) (28ms)
+31ms ║╔Execution stage started
+44ms ║║Calculating (string) This is the Response: + (string) [:] >> (string) This is the Response: [:]
+47ms ║║This is the Response: [:]
+48ms ║║Executed virtual command log (1ms)
+52ms ║║Error parsing JSON data [:]
+53ms ║║Executed virtual command parseJson (2ms)
+58ms ║║Calculating (string) Status2: + (string) [:] >> (string) Status2: [:]
+61ms ║║Status2: [:]
+62ms ║║Executed virtual command log (1ms)
+68ms ║║Calculating (string) ResponseText: + (string) null >> (string) ResponseText: null
+71ms ║║ResponseText: null
+71ms ║║Executed virtual command log (1ms)
+73ms ║╚Execution stage complete. (42ms)
+74ms ╚Event processed successfully (74ms)
4/24/2021, 11:08:53 AM +486ms
+0ms ╔Received event [Home].wc_async_reply = httpRequest with a delay of 0ms
+41ms ║RunTime Analysis CS > 25ms > PS > 6ms > PE > 11ms > CE
+44ms ║Runtime (38036 bytes) successfully initialized in 6ms (v0.3.113.20210203) (42ms)
+44ms ║╔Execution stage started
+55ms ║║Calculating (string) This is the Response: + (string) [:] >> (string) This is the Response: [:]
+58ms ║║This is the Response: [:]
+59ms ║║Executed virtual command log (1ms)
+62ms ║║Error parsing JSON data [:]
+62ms ║║Executed virtual command parseJson (1ms)
+68ms ║║Calculating (string) Status2: + (string) [:] >> (string) Status2: [:]
+71ms ║║Status2: [:]
+77ms ║║Calculating (string) ResponseText: + (string) null >> (string) ResponseText: null
+80ms ║║ResponseText: null
+81ms ║║Executed virtual command log (1ms)
+82ms ║╚Execution stage complete. (38ms)
+83ms ╚Event processed successfully (83ms)
4/24/2021, 11:08:53 AM +306ms
+1ms ╔Received event [Home].test = 1619276933306 with a delay of 0ms
+33ms ║RunTime Analysis CS > 17ms > PS > 5ms > PE > 10ms > CE
+36ms ║Runtime (38028 bytes) successfully initialized in 5ms (v0.3.113.20210203) (34ms)
+37ms ║╔Execution stage started
+42ms ║║Cancelling statement #1’s schedules…
+49ms ║║Sending external web request to: api.kloee.com/api/webhooks/8f527a40-f7fc-45f4-9f7c-8e40ceb5f0bc
+88ms ║║Executed virtual command httpRequest (40ms)
+98ms ║║Requesting a wake up for Sat, Apr 24 2021 @ 11:09:17 AM EDT (in 24.0s)
+130ms ║╚Execution stage complete. (93ms)
+140ms ║Setting up scheduled job for Sat, Apr 24 2021 @ 11:09:17 AM EDT (in 23s)
+148ms ╚Event processed successfully (148msPreformatted text)
