I have created a very simple piston to create two different lighting schemes with a Samsung button. As I’ve played with it, it always seems to trigger up to 3 different light changes during one execution using values that I may have previously used in a previous iteration of the piston. I have made sure I don’t have anything in the Smartthings app assigned to the button (I did very early on use the app to trigger a scene but have since deleted that behavior, and also the scene just to be safe) however it does appear to be landing on the settings that were in that scene. I can’t help feeling I’m missing some basic step as a few pistons I’ve been playing with lately seems to be exhibiting this simultaneous execution of multiple conflicting instructions and saving piston changes doesn’t always seem to take.
I expect one execution of the light change.
Logs show one of the lights being changed 6 times! (based on level entries) in one execution and not landing on the current settings in the piston. Visually it lands on my current color / level settings briefly, then it changes to another color (salmon as in the piston, but then to blue, a color I was using previously). Judging by all the different level settings, they all look like older versions of the piston I was experimenting with, it’s as if every previous version of the piston i’ve saved is running at once. I have also tried rebooting the hub, just in case.
12/24/2020, 7:21:23 AM +207ms
+1ms ╔Received event [Office Master Button].button = pushed with a delay of 69ms
+56ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 33ms > CE
+58ms ║Runtime (40547 bytes) successfully initialized in 6ms (v0.3.110.20191009) (56ms)
+59ms ║╔Execution stage started
+66ms ║║Comparison (enum) pushed gets (string) pushed = true (0ms)
+68ms ║║Cancelling condition #2’s schedules…
+69ms ║║Condition #2 evaluated true (5ms)
+70ms ║║Cancelling condition #1’s schedules…
+71ms ║║Condition group #1 evaluated true (state changed) (7ms)
+73ms ║║Cancelling statement #5’s schedules…
+84ms ║║Executed physical command [Desk Light].setLevel([100]) (6ms)
+85ms ║║Executed [Desk Light].setLevel (7ms)
+93ms ║║Executed physical command [Desk Light].setColor([[hex: #FFA07A, hue:5, saturation:100, level:74]]) (6ms)
+94ms ║║Executed [Desk Light].setColor (8ms)
+96ms ║║Cancelling statement #8’s schedules…
+107ms ║║Executed physical command [Office Cabinet].setLevel([100]) (5ms)
+108ms ║║Executed [Office Cabinet].setLevel (7ms)
+114ms ║║Executed physical command [Office Cabinet].setColor([[hex: #0000FF, hue:67, saturation:100, level:50]]) (3ms)
+114ms ║║Executed [Office Cabinet].setColor (5ms)
+117ms ║║Cancelling statement #11’s schedules…
+127ms ║║Executed physical command [Office Lamp].setColorTemperature([2800]) (6ms)
+128ms ║║Executed [Office Lamp].setColorTemperature (7ms)
+134ms ║║Executed physical command [Office Lamp].setLevel([100]) (3ms)
+135ms ║║Executed [Office Lamp].setLevel (5ms)
+137ms ║║Cancelling statement #14’s schedules…
+903ms ║║Executed physical command [PC].on() (763ms)
+904ms ║║Executed [PC].on (765ms)
+907ms ║║Cancelling statement #3’s schedules…
+955ms ║║Executed physical command [Office Celing Light].setLevel([15]) (44ms)
+956ms ║║Executed [Office Celing Light].setLevel (44ms)
+961ms ║║Comparison (enum) pushed gets (string) held = false (0ms)
+963ms ║║Condition #17 evaluated false (4ms)
+964ms ║║Condition group #16 evaluated false (state did not change) (5ms)
+966ms ║╚Execution stage complete. (906ms)
+967ms ╚Event processed successfully (966ms)
