I have a strange issue were a variable is changing without me (or seemingly WC) knowing
When I come home, a piston that monitors my presence via my iPhone sets some variables (am I home?, how many are home?, etc). Once set, should stay set until presence changes again.
I come home, the presence variables are set correctly but then when I look in WC, they are not set correctly but my piston that monitors changes to this variable does not see a change.
Note in the log I left at 3:05:39 and presence changed to false. Hourly check at 3:07 showed still false. Came back at 3:27 and presence changed to true but then look at the variable value on the right and it is false but no trigger for it becoming false. When I force run the presence check, the variable changes back to true and again no indication of change in this piston and it stays true.
Anyone know what might be happening? It is frustrating since the thermostat is set based on if anyone is home and it keeps switching to no-one home right after I get home but I can’t figure out what is causing it.
