**1) The Global variable that tracks the current mode (@locationMode) is not correctly being reset to “Home” when a house occupant together with their presence sensor (iPhone) returns Home.
**2) The Set Vacation Mode piston incrementally transitions home thermostats to Away Mode and then to Extended Away modes based on the non-presence of all home occupants for a specified amount of time. When all presence sensors show No presence, the piston starts a 4-hour timer and then switches mode to “Away” and adjusts thermostats to save energy. Two global variables are set: one that shows the previous mode (Home), and one that shows the current mode: Away. Another timer is set for 20 hours. At the end of 20 hours, the mode is switched to “Away-Extended Absence” and thermostats are adjusted further to save even more energy. The global variables are updated. If at any time during these waiting periods, a presence sensor is detected to be present, all pending tasks are canceled, the mode is switched back to Home, the thermostats are adjusted for comfort, and the global variables are updated.
**3) The log below shows that at 6:51 am, the piston correctly determines that no one is home; it schedules an execution to run in four hours and then exits (I would have thought it would just pause for four hours, but apparently it sets a time to begin executing the piston, presumably at the very next statement after the Wait statement, and then terminates its current execution). We see at 10:51 that morning, with no one having returned home, the piston indeed picks up execution at the next step by executing a set LocationMode command, setting the two global variables, and then running the routines to adjust all three house thermostats to an energy savings mode. So far so good. At 1:45 in the afternoon, one person returns home, and the piston runs to restore the thermostats to a comfort setting, but we see that in the comparison of @locationMode to “Away” or “Away-Extended Absence” it reveals that @locationMode is still set to Home. Then for some reason, about 1 second later, the piston executes again, initiated by some unknown event (but not another presence sensor). At 3:34 pm, a second person comes home and when the piston runs in response to a second presence sensor change, we see that @locationMode is now set to “Away”, even though the first person has been home for an hour and 35 minutes. Why is @locationMode not correctly reflecting the updated mode?
11/22/2019, 3:34:39 PM +228ms
+2ms ╔Received event [Matt’s iPhone].presence = present with a delay of 75ms
+318ms ║RunTime Analysis CS > 28ms > PS > 243ms > PE > 46ms > CE
+320ms ║Runtime (49900 bytes) successfully initialized in 243ms (v0.3.10e.20190628) (318ms)
+321ms ║╔Execution stage started
+331ms ║║Comparison (enum) present is (string) not present = false (2ms)
+332ms ║║Cancelling condition #6’s schedules…
+333ms ║║Condition #6 evaluated false (6ms)
+334ms ║║Condition group #5 evaluated false (state did not change) (7ms)
+341ms ║║Comparison (dynamic) Away is (string) Away = true (1ms)
+342ms ║║Cancelling condition #11’s schedules…
+343ms ║║Condition #11 evaluated true (6ms)
+344ms ║║Cancelling condition #10’s schedules…
+345ms ║║Condition group #10 evaluated true (state changed) (8ms)
+346ms ║║Cancelling condition #9’s schedules…
+347ms ║║Condition group #9 evaluated true (state changed) (11ms)
+350ms ║║Cancelling statement #25’s schedules…
+2305ms ║║Executed virtual command executeRoutine (1952ms)
+2542ms ║║Executed virtual command executeRoutine (234ms)
+3102ms ║║Executed virtual command executeRoutine (558ms)
+3112ms ║║Comparison (enum) off is (string) off = true (2ms)
+3113ms ║║Condition #40 evaluated true (8ms)
+3114ms ║║Condition group #29 evaluated true (state did not change) (9ms)
+3116ms ║║Evaluating switch with values [[i:29:null:0, v:[t:datetime, v:1574454882344, d:1, vt:string]]]
+3121ms ║║Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+3122ms ║║Calculating (error) Variable ‘00’ not found : (error) Variable ‘00’ not found >> (error)
+3127ms ║║Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+3128ms ║║Calculating (error) Variable ‘05’ not found : (integer) 14 >> (error)
+3132ms ║║Comparison (datetime) 1574454882344 is_inside_of_range (string) … (string) = false (2ms)
+3136ms ║║Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+3137ms ║║Calculating (integer) 21 : (error) Variable ‘00’ not found >> (integer)
+3141ms ║║Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
+3142ms ║║Calculating (integer) 23 : (integer) 59 >> (integer)
+3146ms ║║Comparison (datetime) 1574454882344 is_inside_of_range (integer) 0 … (integer) 0 = false (2ms)
+3149ms ║╚Execution stage complete. (2828ms)
+3150ms ╚Event processed successfully (3150ms)
11/22/2019, 1:45:38 PM +298ms
+1ms ╔Received event [Home].:6ef6def0f2e8b366d3dc83a1ef0d3eca: = @locationMode with a delay of 72ms
+224ms ║RunTime Analysis CS > 22ms > PS > 148ms > PE > 54ms > CE
+227ms ║Runtime (49923 bytes) successfully initialized in 148ms (v0.3.10e.20190628) (226ms)
+228ms ║╔Execution stage started
+233ms ║╚Execution stage complete. (6ms)
+234ms ╚Event processed successfully (234ms)
11/22/2019, 1:45:37 PM +818ms
+1ms ╔Received event [Barbara’s iPhone].presence = present with a delay of 75ms
+226ms ║RunTime Analysis CS > 25ms > PS > 154ms > PE > 47ms > CE
+229ms ║Runtime (49905 bytes) successfully initialized in 154ms (v0.3.10e.20190628) (226ms)
+230ms ║╔Execution stage started
+242ms ║║Comparison (enum) not present is (string) not present = true (2ms)
+244ms ║║Condition #6 evaluated true (8ms)
+248ms ║║Comparison (enum) present is (string) not present = false (1ms)
+250ms ║║Cancelling condition #7’s schedules…
+250ms ║║Condition #7 evaluated false (6ms)
+251ms ║║Cancelling condition #5’s schedules…
+252ms ║║Condition group #5 evaluated false (state changed) (17ms)
+259ms ║║Comparison (dynamic) Home is (string) Away = false (1ms)
+260ms ║║Condition #11 evaluated false (5ms)
+264ms ║║Comparison (dynamic) Home is (string) Away-Extended Absence = false (1ms)
+266ms ║║Condition #12 evaluated false (5ms)
+267ms ║║Condition group #10 evaluated false (state did not change) (12ms)
+268ms ║║Condition group #9 evaluated false (state did not change) (14ms)
+277ms ║║Comparison (enum) off is (string) off = true (1ms)
+279ms ║║Condition #14 evaluated true (9ms)
+280ms ║║Condition group #13 evaluated true (state did not change) (10ms)
+282ms ║║Cancelling statement #20’s schedules…
+284ms ║║Executed virtual command cancelTasks (0ms)
+354ms ║║Executed virtual command setLocationMode (66ms)
+357ms ║║Executed virtual command setVariable (1ms)
+361ms ║║Executed virtual command setVariable (1ms)
+369ms ║╚Execution stage complete. (140ms)
+371ms ╚Event processed successfully (370ms)
11/22/2019, 10:51:13 AM +89ms
+0ms ╔Received event [Home].time = 1574437874631 with a delay of -1543ms
+252ms ║RunTime Analysis CS > 38ms > PS > 172ms > PE > 42ms > CE
+254ms ║Runtime (49898 bytes) successfully initialized in 172ms (v0.3.10e.20190628) (253ms)
+255ms ║╔Execution stage started
+593ms ║║Executed virtual command setLocationMode (323ms)
+598ms ║║Executed virtual command setVariable (2ms)
+604ms ║║Executed virtual command setVariable (1ms)
+2979ms ║║Executed virtual command executeRoutine (2372ms)
+3678ms ║║Executed virtual command executeRoutine (696ms)
+3957ms ║║Executed virtual command executeRoutine (276ms)
+3960ms ║║Executed virtual command wait (0ms)
+3961ms ║║Requesting a wake up for Sat, Nov 23 2019 @ 6:51:17 AM EST (in 72000.0s)
+3966ms ║╚Execution stage complete. (3711ms)
+3968ms ║Setting up scheduled job for Sat, Nov 23 2019 @ 6:51:17 AM EST (in 71999.995s)
+3978ms ╚Event processed successfully (3978ms)
11/22/2019, 6:51:14 AM +355ms
+1ms ╔Received event [Andrew’s iPhone].presence = not present with a delay of 76ms
+233ms ║RunTime Analysis CS > 34ms > PS > 154ms > PE > 45ms > CE
+236ms ║Runtime (49906 bytes) successfully initialized in 154ms (v0.3.10e.20190628) (233ms)
+237ms ║╔Execution stage started
+249ms ║║Comparison (enum) not present is (string) not present = true (1ms)
+251ms ║║Condition #6 evaluated true (8ms)
+258ms ║║Comparison (enum) not present is (string) not present = true (1ms)
+260ms ║║Condition #7 evaluated true (7ms)
+264ms ║║Comparison (enum) not present is (string) not present = true (1ms)
+266ms ║║Cancelling condition #8’s schedules…
+266ms ║║Condition #8 evaluated true (6ms)
+268ms ║║Cancelling condition #5’s schedules…
+268ms ║║Condition group #5 evaluated true (state changed) (25ms)
+271ms ║║Cancelling statement #41’s schedules…
+274ms ║║Executed virtual command wait (1ms)
+275ms ║║Requesting a wake up for Fri, Nov 22 2019 @ 10:51:14 AM EST (in 14400.0s)
+280ms ║╚Execution stage complete. (43ms)
+281ms ║Setting up scheduled job for Fri, Nov 22 2019 @ 10:51:14 AM EST (in 14399.996s)
+290ms ╚Event processed successfully (289ms)
