I am trying to use a global variable in one piston to create a true/false scenario which can then be used in a separate piston to perform an action.
Have a globally defined variable perform/not perform certain action in another piston.
The piston that defines the global variable is still appearing as a local variable, even when defined with @ in the front. I am not sure if I am simply messing up the definition of the global variable (First time attempting to use one). Additionally, when @ is placed in the front of the variable it appears as _(Variablename) in the piston.
