I have a piston that I’ve been using for quite some time that kicks off based on presence. Lately, the second half of the piston (which should kick in when either of 2 phones arrive, as long as the location mode is either ‘Away’ or ‘Nanny’ and we’ve been gone for at least 5 minutes) has not been kicking in at all. The first half, which kicks off when we leave, is still working just fine. The issue is probably obvious in the logs, but I can’t figure out all the “Comparison group xyz” stuff.
2nd half of piston should kick off when either of 2 phones arrive, as long as the location mode is either ‘Away’ or ‘Nanny’ and we’ve been gone for at least 5 minutes.
Presence sensor is arriving properly (I can watch the status change in ActionTiles as I pull up to the house). But the piston never kicks in.
12/11/2020, 5:54:00 PM +365ms
+1ms ╔Received event [Steven’s Pixel 3 XL].presence = present with a delay of 98ms
+102ms ║RunTime Analysis CS > 23ms > PS > 22ms > PE > 57ms > CE
+105ms ║Runtime (48041 bytes) successfully initialized in 22ms (v0.3.110.20191009) (103ms)
+121ms ║║Comparison (enum) not present is_not (string) present = true (2ms)
+124ms ║║Comparison (enum) present is_not (string) present = false (1ms)
+125ms ║║Cancelling condition #4’s schedules…
+126ms ║║Condition #4 evaluated false (14ms)
+127ms ║║Cancelling condition #3’s schedules…
+128ms ║║Condition group #3 evaluated false (state changed) (16ms)
+138ms ║║Comparison (enum) not present is (string) present = false (2ms)
+141ms ║║Comparison (enum) present is (string) present = true (1ms)
+142ms ║║Condition #36 evaluated true (12ms)
+147ms ║║Comparison (string) :d9dd57670e2045f82e647efa357a2ed8: is_any_of (string) :e58934e6194ea25b11f64fb3339a96b1:,:d9dd57670e2045f82e647efa357a2ed8: = true (2ms)
+149ms ║║Cancelling condition #37’s schedules…
+150ms ║║Condition #37 evaluated true (7ms)
+215ms ║║Duration 2742596ms for was_not >= 300000ms threshold = true
+216ms ║║Comparison (enum) not present was_not (string) present = true (58ms)
+293ms ║║Comparison (enum) present was_not (string) present = false (76ms)
+295ms ║║Condition #38 evaluated false (144ms)
+297ms ║║Condition group #35 evaluated false (state did not change) (167ms)
+299ms ║║Condition group #7 evaluated true (state did not change) (0ms)
+302ms ║╚Execution stage complete. (196ms)
+303ms ╚Event processed successfully (303ms)
