Hi all,
Been a while since I’ve posted here, mainly as everything is running reasonably well and I found most new threads were repeats of older ones. I am sure I am about to commit the sin of starting a new thread on a subject already discussed, but here goes.
I am getting a lot of piston waited at a semaphore in my logs across a number of my pistons. I’ve tried simply telling WebCoRE to run pistons in parallel, but it’s not helped. I could use some advice on the best setups, I have numbers of pistons which are triggered by the same devices.
Cheers all.
