Heatsetpoint and the Nest
I am trying to set the heat and cooling set point but not sure if I have the right DH for the nest because every time I try to set it I get an error. Has anyone gotten this to work on the NEST
Are you using @tonesto7 nest suite of DH/smart app?
yep…I guess I need to create a new nest token. I was told once I figure that out I should be good
