Help: github installation: don't have access to repository
I am getting an error " you don’t have access ady624/webCoRE" when I try to add a repository when installing webCoRE for the first time.)
to have access to the repository
i can’t add the repository to install webCoRE!
webcore atdd repo
webcore add repo not allowed
NA
Have you ‘forked’ the repository to your github account.
I don’t know if this is the reason but it might be.
Alternatively you could cut and paste in the 4 elements. Not ideal I know but it will get you started while you figure out what is wrong.
A few people had this error earlier and were able to resolve it by disconnecting ST from their GitHub account then reconnecting. More details here
THANK YOU that did the trick
I have had the same issue so have been having to update my WebCoRE manually by copying the source - is there any risk of losing all my pistons, etc if I am able to get GitHub working and clone from there? I don’t really know where my pistons, etc are stored and am a bit afraid of losing my config!
I have made a backup but it sounds like restore is not yet working, so I would be left manually re-entering from the screenshots and that does not sound fun. Can anyone else who has gone thru this process confirm if it works to switch to GitHub from a manual install?
I am trying to add webCoRE at the moment, but am getting the ‘don’t have access’ message.
Is some part of the smartthings infrastructure down?
Or is it me!
https://status.smartthings.com/incidents/7kygbn2sdwcf
Webcore stopped working - any ideas why?
Thanks for the link.
