My internet is very intermittent. Still working w/ my ISP to get it fixed (I also like bashing my head against a wall. Both fun things to do). Anyways, it would be very useful to have a zigbee light turn on in the living room whenever the internet is down. This would help my toddler know why Bluey stopped playing. “when the red light in the corner is on, that means Bluey might not play for a few minutes”.
Anyways, I can’t figure out how to write a piston to “check if I have internet”. I’m assuming some kind of “make GET request to the-googler.com”. But what do I do with that? Is there some kind of variable/argument that comes out of that line? How do I construct an if-statement in webcore to check for internet?
I want to write a piston like this (pseudocode)
Timer: Every 60 seconds
if internet is down (ping google.com != success)
then Zigbee Corner Bulb, turn on, 100%, Red color
elseif internet is reachable (ping google.com == success)
then Zigbee Corner Bulb, turn off
end
Can’t figure out how to set up the piston for the internet status (the if-statement portion)
5/15/2024, 10:25:29 PM +392ms
+4ms ╔Received event [Hub8].time = 1715826329362 with a delay of 30ms, canQueue: true, calledMyself: false
+36ms ║RunTime initialize > 35 LockT > 1ms > r9T > 24ms > pistonT > 22ms (first state access 6 m:10 5 30)
+39ms ║Runtime (7290 bytes) initialized in 24ms (v0.3.114.20230828_HE)
+47ms ║╔Execution stage started
+55ms ║║scheduleTimer Requesting every schedule wake up at Wed, May 15 2024 @ 10:25:59 PM EDT (in 29916ms) for 1 (st:-1)
+62ms ║║Comparison (boolean) null is (boolean) false = true (5ms)
+63ms ║║Condition #5 evaluated true (7ms)
+65ms ║║Condition group #4 evaluated true (condition did not change) (9ms)
+70ms ║║Command optimization: Skipped execution of device command [Corner bulb].on() because it would make no change to the device. (1ms)
+99ms ║║Executed device command [Corner bulb].setColor([hex: #FF0000, hue:0, saturation:100, level:50]) (22ms)
+101ms ║║Exiting piston at end of Every timer block
+105ms ║╚Execution stage complete. (58ms)
+163ms ║Setting up scheduled job for Wed, May 15 2024 @ 10:25:59 PM EDT (in 29859ms)
+165ms ╚Event processed successfully (162ms)
