Help referencing device attribution from device array
I’m having a hard time referencing a device’s attributes (capability) when using a device list.
here is the code, bolded underline is what I would like to define
device humidifierList = Bedroom Humidifier and Downstairs Humidifier
foreach ($device in {humidifierLlist})
do
if ($device:humidity is outside of range (targetHumidity - hysteresisValue) and targetHumidity)
thanks!
Use
[$device : humidity]
to retrieve the humidity for a device. Put that in an expression field
excellent, thanks!
