Wooh must admit most of that is beyond me
but i will give it a go tomorrow when i can get my head around it getting late here (UK)
one thing i did notice on that is you capture the attributes on a separate “with” to the restore shall i separate mine?
And noticed on mine it says after the capture “Only if store is empty” but yours doesn’t say whys that.
Thanks for all your help
Help restoring previous state on LEDs
ehh, if you look through it a bit i am sure you will figure it out.
ok.
no that was just the flow for my piston.
yeah, i was thinking about that. lets remove that for now. just dont hold on to the button multiple times within seconds of each other, so the captured valuea do not get overwritten.
Thanks for all your effort with that pal…
But that didn’t work either stays green all the time.
Maybe it’s like you say it’s the device not allowing it I’ll try and contact the guy who wrote the firmware to see his thoughts.
It’s not a bulb it’s a RGB controller (H801) for my LED step lights.
I flashed it with SmartThings firmware which works great.
There is a setting in the Smartapp to restore previous state on boot so it must remember.
community.smartthings.com/t/release-smartlife-h801-rgbw-led-strip-wifi-controller
Sorry about the late reply I got a message saying reached maximum posts for a new member lol
ok. if you dont mind my asking the obvious, did you import the piston i posted or modify the one you had, for the last try?
Hi sorry been in bed night time here
Yeah I imported your piston , I’ve just imported that piston but can’t test it till later now as I’m in work
Thanks
Just tried that latest one and it didnt work either
I did notice though after the 10 second wait the light flickered but stayed green and also if the lights are off when the piston runs it will flash green then turn off as it should its only when the lights are on it doesn’t work properly.
From what i can make out it seems to run and do what it should i can’t see any errors
24/08/2017, 19:17:09 +180ms
+0ms ╔Received event [Home].time = 1503598630837 with a delay of -1658ms
+135ms ║RunTime Analysis CS > 24ms > PS > 50ms > PE > 62ms > CE
+149ms ║Runtime (41230 bytes) successfully initialized in 50ms (v0.2.0e5.20170812) (147ms)
+150ms ║╔Execution stage started
+196ms ║║Restoring attribute ‘level’ to value ‘79’ using command setLevel(79)
+333ms ║║Executed physical command [Kitchen Counter LED].setLevel([79]) (136ms)
+334ms ║║Executed virtual command [Kitchen Counter LED].loadStateLocally (153ms)
+339ms ║║Executed virtual command [Kitchen Counter LED].wait (1ms)
+340ms ║║Waiting for 1000ms
+1364ms ║║Restoring attribute ‘saturation’ to value ‘’ using command setSaturation()
+1390ms ║║Executed physical command [Kitchen Counter LED].setSaturation([]) (25ms)
+1390ms ║║Executed virtual command [Kitchen Counter LED].loadStateLocally (42ms)
+1396ms ║║Executed virtual command [Kitchen Counter LED].wait (0ms)
+1396ms ║║Waiting for 1000ms
+2421ms ║║Restoring attribute ‘color’ to value ’ #dd00e2’ using command setColor( #dd00e2)
+2448ms ║║Executed physical command [Kitchen Counter LED].setColor([ #dd00e2]) (26ms)
+2449ms ║║Executed virtual command [Kitchen Counter LED].loadStateLocally (43ms)
+2454ms ║║Executed virtual command [Kitchen Counter LED].wait (0ms)
+2455ms ║║Waiting for 1000ms
+3480ms ║║Restoring attribute ‘hue’ to value ‘0.0’ using command setHue(0.0)
+3589ms ║║Executed physical command [Kitchen Counter LED].setHue([0.0]) (108ms)
+3590ms ║║Executed virtual command [Kitchen Counter LED].loadStateLocally (127ms)
+3595ms ║║Executed virtual command [Kitchen Counter LED].wait (1ms)
+3596ms ║║Waiting for 1000ms
+4610ms ║║Restoring attribute ‘switch’ to value ‘on’ using command on()
+4633ms ║║Executed physical command [Kitchen Counter LED].on() (22ms)
+4633ms ║║Executed virtual command [Kitchen Counter LED].loadStateLocally (28ms)
+4637ms ║╚Execution stage complete. (4488ms)
+4644ms ╚Event processed successfully (4645ms)
24/08/2017, 19:16:59 +18ms
+1ms ╔Received event [Alarm Button].button = held with a delay of 81ms
+141ms ║RunTime Analysis CS > 25ms > PS > 60ms > PE > 56ms > CE
+149ms ║Runtime (41230 bytes) successfully initialized in 60ms (v0.2.0e5.20170812) (148ms)
+166ms ║║Comparison (enum) held gets (string) held = true (1ms)
+171ms ║║Cancelling statement #3’s schedules…
+186ms ║║Executed virtual command setAlarmSystemStatus (12ms)
+188ms ║║Condition #2 evaluated true (29ms)
+190ms ║║Condition group #1 evaluated true (state did not change) (30ms)
+193ms ║║Cancelling statement #5’s schedules…
+208ms ║║79
+208ms ║║Executed virtual command [Kitchen Counter LED].log (1ms)
+220ms ║║0
+221ms ║║Executed virtual command [Kitchen Counter LED].log (1ms)
+233ms ║║ #dd00e2
+234ms ║║Executed virtual command [Kitchen Counter LED].log (1ms)
+245ms ║║0
+246ms ║║Executed virtual command [Kitchen Counter LED].log (2ms)
+258ms ║║on
+259ms ║║Executed virtual command [Kitchen Counter LED].log (1ms)
+289ms ║║Executed virtual command [Kitchen Counter LED].saveStateLocally (23ms)
+1757ms ║║Executed physical command [Kitchen Counter LED].setLevel([100]) (1463ms)
+1758ms ║║Executed [Kitchen Counter LED].setLevel (1465ms)
+1811ms ║║Executed physical command [Kitchen Counter LED].setColor([[hex: #05ff00, hue:33, saturation:100, level:25]]) (47ms)
+1812ms ║║Executed [Kitchen Counter LED].setColor (50ms)
+1817ms ║║Executed virtual command [Kitchen Counter LED].wait (0ms)
+1818ms ║║Requesting a wake up for Thu, Aug 24 2017 @ 7:17:10 PM BST (in 10.0s)
+1825ms ║╚Execution stage complete. (1675ms)
+1827ms ║Setting up scheduled job for Thu, Aug 24 2017 @ 7:17:10 PM BST (in 9.993s)
+1843ms ╚Event processed successfully (1843ms)
actually please delete line 47, 48 and 51, 52 and try it again.
so remove the restore statement for saturation and hue and their corresponding waits.
just tried still no luck.
i’m not sure how you see the values for statements
is it in that evaluation console?
i set it to value but didn’t know what to put lol
if you have no more ideas don’t worry about it i’ll leave it as i’m not that bothered about getting it to work i just thought it would be handy
from the logs you shared here are the values. in seq, they are level, saturation, color, hue and switch. as you can see only level, color and switch have a value. so, we should only capture and restore level, color and switch values and not the others.
if you do update the piston with this, please share an anonymized snapshot of the piston.
thanks.
Changed Them and still the same lol
Thanks for all your help on this I think I’m going to leave it now it’s taking up to much of both our time.
Thanks for all your help though
too bad. yeah, i am not feeling like we are making any progress with this one.
next step would be to look at the live logging in the IDE and see if can get more details of what might be happening.
but, like you say may not be worth the trouble :-/
sorry.
