HELP to get min value from variable
I need to get min and max value from variable LastMotionList.
(PUT YOUR INFO HERE)
Thanks for help.
The two expressions are:
min(data1, data2, data3)
max(data1, data2, data3)
as seen here in the Wiki.
Thanks for the reply and link to the"min" function description.
I would like to ask if there is a way to use “min” function directly for variable “LastMotionList” where are inactive times for each device (example “Garage Motion Sensor:1788” ).
Would be great to be able to do “min” function just to the second parameter of each device (inactive time example 1788).
Thanks for help
I think it will be less code, and less hassle if you drop the loop, and just hard code it:
pic
Edit: Updated image to show the required “.0”
Thank you very much for help!
