Help with a trio of pistons that are based in home mode
I’ll have to post pistons when I get home but I essentially have a trio of motion based night light pistons. Problem is, they are based off Night mode. With sunrise getting later until DST, I’ve had issues where the Piston gets triggered, the house mode changes to Home, and the lights remain on. It’s more of an annoyance, BUT, I also have the SHM and thermostats that work around this, so I’m wondering what the appropriate path forward would be.
Perhaps time based? I.e. a Piston that would change from Night to Home at x time? That seems to not work because sunrise is consistently earlier/later depending in the date.
Fixing the pistons for lights is easy. Fixing the pistons for HVAC setback and automatic SHM disarm is a little harder.
Try using a time trigger with a preset of between sunset and sunrise. It adjust daily automatically.
If Time is between sunset and sunrise
Then do action
End if
