I have designed a piston for a heater to automatically come on when the temp is below 2oc. I want it only to work between 10pm and 6pm the following day and when active go off after 20mins
(PUT YOUR INFO HERE)
The temp goes below 2 but the switch doesn’t activate. If I turn the switch on however it tells me it’s active notifies my phone and goes off after 20mins like a asked
