I changed my piston to look similar to above but still have the same issue.
Here are the logs.
11/03/2021, 21:12:51 +822ms
+3ms ╔Received event [Hubitat Smart Home Hub].execute = [XXX.XXX.XXX.XXX, XXX.XXX.XXX.XXX] with a delay of 32ms,canQueue: true, calledMyself: false
+24ms ║RunTime initialize > 22 LockT > 0ms > rtDT > 1ms > pistonT > 0ms (first state access 21 3 19)
+27ms ║Runtime (7988 bytes) successfully initialized in 1ms (v0.3.113.20210211_HE)
+28ms ║╔Execution stage started
+34ms ║║Comparison (string) :7c76bcf13f4437d56396ddf04776b595: is (string) :7c76bcf13f4437d56396ddf04776b595: = true (1ms)
+35ms ║║Condition #9 evaluated true (5ms)
+45ms ║╚Execution stage complete. (17ms)
+75ms ║Setting up scheduled job for Thu, Mar 11 2021 @ 9:30:01 PM GMT (in 1029498ms),with 1 more job pending
+77ms ╚Event processed successfully (77ms)
11/03/2021, 21:00:00 +790ms
+5ms ╔Received event [Hubitat Smart Home Hub].time = 1615496400731 with a delay of 59ms,canQueue: true, calledMyself: false
+23ms ║RunTime initialize > 21 LockT > 1ms > rtDT > 1ms > pistonT > 0ms (first state access 19 6 15)
+27ms ║Runtime (7839 bytes) successfully initialized in 1ms (v0.3.113.20210211_HE)
+33ms ║╔Execution stage started
+55ms ║║Condition #35 evaluated false (10ms)
+56ms ║║Condition group #34 evaluated false (state did not change) (12ms)
+58ms ║║Cancelling statement #36’s schedules…
+534ms ║║Executed physical command [Echo - LR’s Echo Dot].playText(Remember to take the bins out) (465ms)
+535ms ║║Executed [Echo - LR’s Echo Dot].playText (466ms)
+545ms ║║Executed virtual command [Echo - LR’s Echo Dot].wait (0ms)
+547ms ║║Requesting a wake up for Thu, Mar 11 2021 @ 9:30:01 PM GMT (in 1800000ms)
+564ms ║╚Execution stage complete. (530ms)
+596ms ║Setting up scheduled job for Thu, Mar 11 2021 @ 9:30:01 PM GMT (in 1800010ms),with 1 more job pending
+598ms ╚Event processed successfully (597ms)
11/03/2021, 20:30:00 +54ms
+6ms ╔Received event [Hubitat Smart Home Hub].time = 1615494600000 with a delay of 54ms,canQueue: true, calledMyself: false
+77ms ║RunTime initialize > 76 LockT > 1ms > rtDT > 56ms > pistonT > 55ms (first state access 19 8 68)
+85ms ║Runtime (7923 bytes) successfully initialized in 56ms (v0.3.113.20210211_HE)
+106ms ║║Cancelling statement #36’s schedules…
+664ms ║║Executed physical command [Echo - LR’s Echo Dot].playText(Remember to take the bins out) (545ms)
+665ms ║║Executed [Echo - LR’s Echo Dot].playText (547ms)
+674ms ║║Executed virtual command [Echo - LR’s Echo Dot].wait (1ms)
+677ms ║║Requesting a wake up for Thu, Mar 11 2021 @ 9:00:00 PM GMT (in 1800000ms)
+689ms ║╚Execution stage complete. (597ms)
+723ms ║Setting up scheduled job for Thu, Mar 11 2021 @ 9:00:00 PM GMT (in 1800013ms),with 1 more job pending
+725ms ╚Event processed successfully (724ms)
11/03/2021, 19:32:54 +738ms
+14ms ╔Subscribing to devices…
+234ms ║Device missing from piston. Loading all from parent (210ms)
+259ms ║Piston controls Kitchen Door Contact Sensor (Rear)…
+260ms ║Piston controls Echo - LR’s Echo Dot…
+291ms ╚Finished subscribing (280ms)
+310ms ║Comparison (string) :7c76bcf13f4437d56396ddf04776b595: is (string) :7c76bcf13f4437d56396ddf04776b595: = true (1ms)
+312ms ║Cancelling condition #9’s schedules…
+403ms ║Setting up scheduled job for Thu, Mar 11 2021 @ 8:30:00 PM GMT (in 3424923ms)
+408ms ╔Starting piston… (v0.3.113.20210211_HE)
+409ms ╚Piston successfully started (401ms)
have edited out the IP Details above and you can see my contact sensor was opened @ 21:06 and 21:09.
I think this isnt working as these statements are executed asynchronously
