Ok I have a couple of pistons here that act as intended except I don’t want the rw piston firing if the wendy car switch turns ryans working back on after being on once, but I need it firing if the wendy car Switch was on the first time.
What I’m trying accomplish is if the wendy car switch is on and the Ryan working switch fires in the morning it will do as intended the first time. the ryan working switch will turn off when the car drives away and the switch needs to come back on without the Rw piston actually firing.
Does this make sense? Lol
