Help with estimated time of arrival!
Working on a commute notification.
The expected behavior is to have Alexa speak the estimated time of arrival.
The format for the time - addMinutes - not in the right format.
My piston uses Google’s DistranceMatrix to find the # of minutes for my commute.
It stores this # in the variable “Traffic”.
I take this number, let’s say it is 50 minutes (Variable = Traffic), and I want to add that # of minutes to the current time.
With that arrival estimate time, I want Alexa to speak "I’ll be home at 5:50pm)
The problem is I can’t get the time to display: 5:50pm.
Instead, it shows the following:
5:00 P.M. Tue, Oct 1 2019 @ 5:50:55 PM EDT
So it is taking the current time (5:00pm) and then displaying what the date/time will be in 50 minutes.
My expression:
$time(addminutes(Traffic))
Thanks in advance!
You’d probably be better off using formatDateTime() function.
https://wiki.webcore.co/Functions#formatDateTime
(expression) formatDateTime(1569946803,"h:mm a") »»» (string) 9:05 PM
Thanks for the help.
That is kind of where I ended up in my testing, but I still get the same output:
(expression)
formatDateTime($time, “h:mm a”)(addMinutes(Traffic))
(output)
12:24 PMTue, Oct 1 2019 @ 12:44:09 PM EDT
I don’t know how to get the output of 12:44PM, w/o any of the other info…
I looked at that reference, but when I add "addMinutes ", the format is lost.
Hmm, it should be…
formatDateTime(addMinutes($time,Traffic),"h:mm a")
Thank you! I wouldn’t have guessed that =)
Working !!
I just checked on this again in another test.
Traffic = Text variable of “20”
formatDateTime(addMinutes($time,Traffic),“h:mm a”)
It is returning an AM time, not a PM.
Do I need to add a time zone or something? It seems to be off by 12 hours.
This returns the correct time:
formatDateTime(addMinutes($time,721),“h:mm a”)
If I evaluate $time, the proper time is returned…
What do you get if you enter this in the evaluation console?
formatDateTime($time,"h:mm a")
I get the proper time, currently it is 9:41am:
formatDateTime($time,“h:mm a”)
Returns: (string) 9:41 AM
I’m not sure what has changed… but if I re-run the piston manually, it now returns the correct/expected time.
formatDateTime(addMinutes($time, Traffic),“h:mm a”)
10:16am
It is currently 9:46, but TRAFFIC=30, so it looks good…
