I’ve got a circadian lighting piston that relies on different chunks of time to operate correctly. They’re all set as “time only” variables. We’ll call them A, B, C, D.
I tried to set this up with a “timer” for “every 15 minutes do…”
and inside, I have the multiple cases. Condition was set as time($now) and the cases are range A to B, and range B to C, and range C to D. Each case has a different action but none of them are actually executing.
Is there something I’m doing wrong or is there a more elegant way to achieve what I’m looking for?
Pic is below. You can ignore everything that’s below the Case/Switch.
