I have a piston that automatically turns off the extractor fan when the humidity level drops back to it’s original level. This is working fine. I need to tweak my piston so that it doesn’t turn off the light after the initial wait period if there has been further motion in the bathroom.
I have a seperate piston that turns the light and extractor on independently from each other depending on the time of day (they are on seperate Fibaro modules). The triggers for the bathroom light are either the light switch or the motion detection from a sensor.
Light stays on whilst someone is in the bathroom and then turns off 20 minutes after no motion.
Light is turning off 20 mins after the extractor is turned on.
