Want lights to fade on in the morning if sunrise is after execution time.
Same as above
Nothing happens. Light don’t come on
Same as above
Check this post out for how to get logs.
https://community.webcore.co/t/how-to-get-the-quickest-answers/1315?u=c1arkbar
Thanks, but I don’t have the logs anymore because they “fell off” the end of the log. However, the following version works. Is there an explanation for why when the
{$sunrise} is after {$now}
restriction is before the execute it would be different than when it’s in the do?
The restriction outside of the execute will restrict the entire piston.
Restriction on actions just restrict that individual actions.
In your case it would make no difference.
