How to set time between 20:00-09:00 (24 hour time)!? What variables do I use.
Best regards
Thekholm
Best regards
Thekholm
I am not sure I understand your question. Can you give us a little more information about what you are trying to accomplish?
Hi,
I want to set my Aeotec Doorbell 6 to volume (0) at 20:00 (evening) to about 9:00 (morning). At 9:00 it should go back to normal, end the piston. Simple as that.
I have got the right code to SetVolume from the guy how wrote the device handler.
Many thanks in advance
Thekholm
Variables are needed IF the same automation needs to behave differently under different circumstances.
(one of the ways of using them ofcourse)
