I am trying to make to restrictions that does not have to be true at the same time.
If either switch 4 or 6 is off run the action.
I want to use this setup with my wake up routine in the bed room and rest of my house. If Switch 4 is on it means it is vacation and none of my morning routines should run (this and other pistons). If switch 6 is on it means that me or my girlfriend has a day off and then I don´t want the piston below to not run.
It seems as though they both have to be true
