I created this piston to manage the space heater in one of our rooms which is plugged into a smart plug and temp is monitored every 60 seconds via USB powered Innoveli 4-in-1 sensor.
Expected this to maintain the room temperature between 70-74 F during the night in Winter months.
Last night, I felt a bit cold and switched on the space heater manually from action-tiles panel, however, the heater kept running until i switched it off and the room was at 89F. Not sure what was missing here? It’s not captured in the logs.
No Logs are captured from that window of time. Seemingly like the piston didn’t even run.
