I’m trying to figure out a way to do the following and just cannot figure it out.
I have three presence sensors all tied to me. Smartthings, WebCore, and a Wi-Fi presence. All work great, and each have a different use. For the most part I use the 1st two to compliment each other to reduce false presence, and it works great. I use the Wi-Fi presence to unlock doors. Something I want to be much closer to the house. It also works great.
Sometimes for various reasons, I have my wi-fi off, and don’t realize it for a while. But maybe someone was already home, so the door did not need to be unlocked, etc. so I did not notice.
I want a piston that runs 15 minutes after I get home, that then checks to see if the wi-fi presence is present or not. But only once. I tried a 1st sensor “Stays present for 15”, and it worked kind of, but if I disconnected my wi-fi later it would trigger again.
Since there may be times I want my phone to be off wi-fi, I really only want this to run one time within the 1st 15 minutes of my arrival at home. Just basically a friendly nudge, that says “Hey, you’re not on wi-fi or there is something wrong.”
