Hold a preset time field in a variable
Ideally, I would like to hold a time preset variable like @sunset in a local variable. I’m trying to hold all my scene definitions in arrays and then use some common code to set up and execute the scene. I have all of it covered except specific times when the scene should be active. Ideally I would like to construct the whole If statement so I can be as flexible as possible.
String FromTime = ‘@sunrise’
If time is after {FromTime + FromTimeOffSet}… Do stuff
Or something like:
String Statement = 'If time is after @sunset
If Statement… Do stuff
Alternatively, if anyone has a better idea for being able to soft code the above I would be most interested.
Just use $sunset. You can put that in another variable if you want.
Thanks for the reply. I think I was over complicating matters. As there’s only two presets (sunrise and set) that change, I can accommodate then with an IF.
Been there. Done that. LOL
