Using the attached piston for years. It never seems to evaluate the date correctly. Every year at christmas I just enable the piston and then after I disable it. Kind of defeats the purpose of the automation.
I expected the code to process the date correctly and alternate the lights only on holidays. Instead it is stuck on christmas all the time.
Not evaluating the date. Prob something wrong with the logic.
1/12/2022, 6:08:21 PM +503ms +1ms ╔Received event [Outside Lights].switch = off with a delay of 63ms +7870ms ║RunTime Analysis CS > 15ms > PS > 7765ms > PE > 90ms > CE +7871ms ║Piston waited at a semaphore for 7761ms +7875ms ║Runtime (74998 bytes) successfully initialized in 7765ms (v0.3.110.20191009) (7873ms) +7876ms ║╔Execution stage started +7883ms ║║Comparison (enum) off changes_to (string) on = false (0ms) +7884ms ║║Cancelling condition #22's schedules... +7885ms ║║Condition #22 evaluated false (5ms) +7886ms ║║Cancelling condition #5's schedules... +7887ms ║║Condition group #5 evaluated false (state changed) (7ms) +7890ms ║║Cancelling statement #46's schedules... +7893ms ║║Executed virtual command setState (0ms) +7899ms ║║Calculating (integer) 15 / (integer) 3 >> (integer) 5 +7904ms ║║Executed virtual command setVariable (3ms) +7912ms ║║Calculating (integer) 100 - (integer) 98 >> (integer) 2 +7918ms ║║Calculating (integer) 5 - (integer) 1 >> (integer) 4 +7920ms ║║Calculating (integer) 2 / (integer) 4 >> (integer) 0.5 +7925ms ║║Executed virtual command setVariable (3ms) +7930ms ║║Executed virtual command setVariable (3ms) +7935ms ║║Executed virtual command setVariable (3ms) +7940ms ║║Executed virtual command setVariable (2ms) +7944ms ║║Executed virtual command setVariable (2ms) +7954ms ║║Comparison (boolean) false is (boolean) false = true (1ms) +7955ms ║║Cancelling condition #38's schedules... +7956ms ║║Condition #38 evaluated true (9ms) +7957ms ║║Cancelling condition #48's schedules... +7958ms ║║Condition group #48 evaluated true (state changed) (10ms) +7960ms ║║Cancelling statement #36's schedules... +7964ms ║║Calculating (integer) 0 + (integer) 1 >> (integer) 1 +7969ms ║║Executed virtual command setVariable (3ms) +7977ms ║║Comparison (boolean) false is (boolean) false = true (2ms) +7978ms ║║Condition #38 evaluated true (8ms) +7979ms ║║Condition group #48 evaluated true (state did not change) (9ms) +7981ms ║║Cancelling statement #36's schedules... +7986ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2 +7990ms ║║Executed virtual command setVariable (3ms) +7998ms ║║Comparison (boolean) true is (boolean) false = false (2ms) +8000ms ║║Cancelling condition #38's schedules... +8001ms ║║Condition #38 evaluated false (9ms) +8002ms ║║Cancelling condition #48's schedules... +8003ms ║║Condition group #48 evaluated false (state changed) (11ms) +8008ms ║║Comparison (boolean) true is (boolean) true = true (2ms) +8009ms ║║Condition #45 evaluated true (4ms) +8014ms ║║Comparison (enum) off is (string) on = false (1ms) +8016ms ║║Condition #229 evaluated false (5ms) +8017ms ║║Condition group #228 evaluated false (state did not change) (6ms) +8018ms ║║Condition group #51 evaluated false (state did not change) (13ms) +8019ms ║╚Execution stage complete. (143ms) +8020ms ╚Event processed successfully (8020ms)
