is the piston getting triggered at the right time every day? if you look at next scheduled in the piston view mode what does it show?
Holiday Lights: 4th of July / Diwali / Halloween / Christmas - Your Pick
Appears to beâŠjust doesnt have the holiday colors loading into the fadecolors unless i manually put it in.
but now that i edited it to manually start it I cant test till its done. If i remove the manually added fadecolors it just fades the white color until its done running at the end of the night.
Last executed: 12/2/2017, 7:20:33 PM
Next scheduled: 12/2/2017, 7:20:43 PM
Subscriptions: no events, 3 controls
Devices used: 3
Memory used: 72% (72366 bytes)
not sure if these "null"s are normal:
12/2/2017, 7:20:42 PM +588ms
+1ms âReceived event [Home].time = 1512267643845 with a delay of -1258ms
+295ms âRunTime Analysis CS > 26ms > PS > 85ms > PE > 184ms > CE
+332ms âRuntime (70519 bytes) successfully initialized in 85ms (v0.2.0ff.20171129) (330ms)
+333ms ââExecution stage started
+360ms ââCancelling condition #nullâs schedulesâŠ
+488ms ââCancelling condition #nullâs schedulesâŠ
+528ms ââCalculating (integer) 53 - (integer) 4 >> (integer) 49
+540ms ââCalculating (integer) 53 - (integer) 4 >> (integer) 49
+547ms ââCalculating (integer) 49 < (integer) 1 >> (boolean) false
+557ms ââCalculating (integer) 53 + (integer) 4 >> (integer) 57
+572ms ââCalculating (integer) 53 + (integer) 4 >> (integer) 57
+578ms ââCalculating (integer) 57 > (integer) 80 >> (boolean) false
+583ms ââCalculating (boolean) false ! (boolean) true >> (boolean) false
+591ms ââExecuted virtual command setVariable (4ms)
+606ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+608ms ââCondition #163 evaluated false (6ms)
+609ms ââCondition group #null evaluated false (state did not change) (8ms)
+612ms ââCancelling statement #72âs schedulesâŠ
+632ms ââExecuted physical command [Driveway].setLevel([57]) (13ms)
+633ms ââExecuted [Driveway].setLevel (14ms)
+648ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+650ms ââCondition #163 evaluated false (6ms)
+651ms ââCondition group #null evaluated false (state did not change) (9ms)
+654ms ââCancelling statement #72âs schedulesâŠ
+668ms ââExecuted physical command [Porch Light 3].setLevel([57]) (8ms)
+669ms ââExecuted [Porch Light 3].setLevel (10ms)
+683ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+685ms ââCondition #163 evaluated false (5ms)
+686ms ââCondition group #null evaluated false (state did not change) (8ms)
+691ms ââCancelling statement #72âs schedulesâŠ
+707ms ââExecuted physical command [Porch Light 4].setLevel([57]) (9ms)
+708ms ââExecuted [Porch Light 4].setLevel (11ms)
+728ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+730ms ââCondition #151 evaluated false (6ms)
+732ms ââCondition group #null evaluated false (state did not change) (8ms)
+735ms ââCancelling statement #74âs schedulesâŠ
+740ms ââExecuted virtual command wait (1ms)
+741ms ââWaiting for 2000ms
+2752ms ââCalculating (integer) 57 - (integer) 4 >> (integer) 53
+2763ms ââCalculating (integer) 57 - (integer) 4 >> (integer) 53
+2767ms ââCalculating (integer) 53 < (integer) 1 >> (boolean) false
+2773ms ââCalculating (integer) 57 + (integer) 4 >> (integer) 61
+2784ms ââCalculating (integer) 57 + (integer) 4 >> (integer) 61
+2788ms ââCalculating (integer) 61 > (integer) 80 >> (boolean) false
+2792ms ââCalculating (boolean) false ! (boolean) true >> (boolean) false
+2797ms ââExecuted virtual command setVariable (3ms)
+2810ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+2812ms ââCondition #163 evaluated false (6ms)
+2813ms ââCondition group #null evaluated false (state did not change) (7ms)
+2816ms ââCancelling statement #72âs schedulesâŠ
+2826ms ââExecuted physical command [Driveway].setLevel([61]) (6ms)
+2826ms ââExecuted [Driveway].setLevel (7ms)
+2839ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+2840ms ââCondition #163 evaluated false (6ms)
+2841ms ââCondition group #null evaluated false (state did not change) (7ms)
+2844ms ââCancelling statement #72âs schedulesâŠ
+2853ms ââExecuted physical command [Porch Light 3].setLevel([61]) (5ms)
+2854ms ââExecuted [Porch Light 3].setLevel (6ms)
+2866ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+2867ms ââCondition #163 evaluated false (6ms)
+2868ms ââCondition group #null evaluated false (state did not change) (7ms)
+2871ms ââCancelling statement #72âs schedulesâŠ
+2880ms ââExecuted physical command [Porch Light 4].setLevel([61]) (4ms)
+2880ms ââExecuted [Porch Light 4].setLevel (6ms)
+2897ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+2898ms ââCondition #151 evaluated false (5ms)
+2899ms ââCondition group #null evaluated false (state did not change) (6ms)
+2902ms ââCancelling statement #74âs schedulesâŠ
+2906ms ââExecuted virtual command wait (1ms)
+2907ms ââWaiting for 2000ms
+4915ms ââCalculating (integer) 61 - (integer) 4 >> (integer) 57
+4925ms ââCalculating (integer) 61 - (integer) 4 >> (integer) 57
+4929ms ââCalculating (integer) 57 < (integer) 1 >> (boolean) false
+4936ms ââCalculating (integer) 61 + (integer) 4 >> (integer) 65
+4947ms ââCalculating (integer) 61 + (integer) 4 >> (integer) 65
+4952ms ââCalculating (integer) 65 > (integer) 80 >> (boolean) false
+4955ms ââCalculating (boolean) false ! (boolean) true >> (boolean) false
+4961ms ââExecuted virtual command setVariable (3ms)
+4975ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+4977ms ââCondition #163 evaluated false (6ms)
+4978ms ââCondition group #null evaluated false (state did not change) (7ms)
+4981ms ââCancelling statement #72âs schedulesâŠ
+4990ms ââExecuted physical command [Driveway].setLevel([65]) (5ms)
+4991ms ââExecuted [Driveway].setLevel (7ms)
+5004ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+5005ms ââCondition #163 evaluated false (6ms)
+5006ms ââCondition group #null evaluated false (state did not change) (7ms)
+5009ms ââCancelling statement #72âs schedulesâŠ
+5019ms ââExecuted physical command [Porch Light 3].setLevel([65]) (5ms)
+5019ms ââExecuted [Porch Light 3].setLevel (6ms)
+5032ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+5033ms ââCondition #163 evaluated false (6ms)
+5034ms ââCondition group #null evaluated false (state did not change) (7ms)
+5037ms ââCancelling statement #72âs schedulesâŠ
+5046ms ââExecuted physical command [Porch Light 4].setLevel([65]) (5ms)
+5047ms ââExecuted [Porch Light 4].setLevel (7ms)
+5063ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+5065ms ââCondition #151 evaluated false (5ms)
+5065ms ââCondition group #null evaluated false (state did not change) (6ms)
+5068ms ââCancelling statement #74âs schedulesâŠ
+5072ms ââExecuted virtual command wait (1ms)
+5073ms ââWaiting for 2000ms
+7080ms ââCalculating (integer) 65 - (integer) 4 >> (integer) 61
+7091ms ââCalculating (integer) 65 - (integer) 4 >> (integer) 61
+7094ms ââCalculating (integer) 61 < (integer) 1 >> (boolean) false
+7101ms ââCalculating (integer) 65 + (integer) 4 >> (integer) 69
+7111ms ââCalculating (integer) 65 + (integer) 4 >> (integer) 69
+7115ms ââCalculating (integer) 69 > (integer) 80 >> (boolean) false
+7118ms ââCalculating (boolean) false ! (boolean) true >> (boolean) false
+7124ms ââExecuted virtual command setVariable (2ms)
+7137ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+7138ms ââCondition #163 evaluated false (6ms)
+7139ms ââCondition group #null evaluated false (state did not change) (7ms)
+7142ms ââCancelling statement #72âs schedulesâŠ
+7151ms ââExecuted physical command [Driveway].setLevel([69]) (5ms)
+7152ms ââExecuted [Driveway].setLevel (7ms)
+7164ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+7166ms ââCondition #163 evaluated false (5ms)
+7167ms ââCondition group #null evaluated false (state did not change) (6ms)
+7170ms ââCancelling statement #72âs schedulesâŠ
+7180ms ââExecuted physical command [Porch Light 3].setLevel([69]) (5ms)
+7181ms ââExecuted [Porch Light 3].setLevel (6ms)
+7192ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+7194ms ââCondition #163 evaluated false (6ms)
+7195ms ââCondition group #null evaluated false (state did not change) (7ms)
+7198ms ââCancelling statement #72âs schedulesâŠ
+7208ms ââExecuted physical command [Porch Light 4].setLevel([69]) (4ms)
+7208ms ââExecuted [Porch Light 4].setLevel (6ms)
+7228ms ââComparison (dynamic) false is (boolean) true = false (3ms)
+7230ms ââCondition #151 evaluated false (8ms)
+7231ms ââCondition group #null evaluated false (state did not change) (9ms)
+7233ms ââCancelling statement #74âs schedulesâŠ
+7237ms ââExecuted virtual command wait (1ms)
+7238ms ââWaiting for 2000ms
+9246ms ââCalculating (integer) 69 - (integer) 4 >> (integer) 65
+9256ms ââCalculating (integer) 69 - (integer) 4 >> (integer) 65
+9260ms ââCalculating (integer) 65 < (integer) 1 >> (boolean) false
+9267ms ââCalculating (integer) 69 + (integer) 4 >> (integer) 73
+9277ms ââCalculating (integer) 69 + (integer) 4 >> (integer) 73
+9281ms ââCalculating (integer) 73 > (integer) 80 >> (boolean) false
+9285ms ââCalculating (boolean) false ! (boolean) true >> (boolean) false
+9291ms ââExecuted virtual command setVariable (3ms)
+9305ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+9306ms ââCondition #163 evaluated false (6ms)
+9307ms ââCondition group #null evaluated false (state did not change) (7ms)
+9311ms ââCancelling statement #72âs schedulesâŠ
+9320ms ââExecuted physical command [Driveway].setLevel([73]) (5ms)
+9321ms ââExecuted [Driveway].setLevel (7ms)
+9333ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+9335ms ââCondition #163 evaluated false (6ms)
+9336ms ââCondition group #null evaluated false (state did not change) (8ms)
+9339ms ââCancelling statement #72âs schedulesâŠ
+9349ms ââExecuted physical command [Porch Light 3].setLevel([73]) (5ms)
+9349ms ââExecuted [Porch Light 3].setLevel (6ms)
+9362ms ââComparison (dynamic) false is (boolean) true = false (2ms)
+9363ms ââCondition #163 evaluated false (6ms)
+9365ms ââCondition group #null evaluated false (state did not change) (7ms)
+9368ms ââCancelling statement #72âs schedulesâŠ
+9377ms ââExecuted physical command [Porch Light 4].setLevel([73]) (5ms)
+9378ms ââExecuted [Porch Light 4].setLevel (6ms)
+9394ms ââComparison (dynamic) false is (boolean) true = false (1ms)
+9396ms ââCondition #151 evaluated false (6ms)
+9397ms ââCondition group #null evaluated false (state did not change) (7ms)
+9400ms ââCancelling statement #74âs schedulesâŠ
+9403ms ââExecuted virtual command wait (1ms)
+9404ms ââRequesting a wake up for Sat, Dec 2 2017 @ 7:20:53 PM MST (in 2.0s)
+9413ms ââExecution stage complete. (9080ms)
+9415ms âSetting up scheduled job for Sat, Dec 2 2017 @ 7:20:53 PM MST (in 1.991s), with 1 more job pending
+9479ms âEvent processed successfully (9479ms)
yeah, that doesnt seem right. if you edit and save the piston does it save ok? how many chunks?
when you look at the trace view do all the trace numberings show fine? or does anything show up as #null?
No nulls in trace. When I remove the manually entered fadecolors it just go back to waiting till tomorrow"
Quick facts
Piston state: false
Last executed: 12/2/2017, 7:49:19 PM
Next scheduled: 12/3/2017, 4:05:00 PM
Devices used: 3
Memory used: 72% (71649 bytes)
12/2/2017, 7:49:19 PM +955ms
+1ms âReceived event [Home].test = 1512269359912 with a delay of 43ms
+254ms âRunTime Analysis CS > 18ms > PS > 55ms > PE > 178ms > CE
+362ms âRuntime (70518 bytes) successfully initialized in 55ms (v0.2.0ff.20171129) (357ms)
+363ms ââExecution stage started
+430ms ââComparison (time) 71360332 happens_daily_at (time) 1512257700000 = false (2ms)
+436ms ââCondition #22 evaluated false (60ms)
+444ms ââCancelling statement #22âs schedulesâŠ
+455ms ââRequesting time schedule wake up at Sun, Dec 3 2017 @ 4:05:00 PM MST
+463ms ââCondition group #5 evaluated false (state did not change) (91ms)
+483ms ââComparison (boolean) true is (boolean) true = true (3ms)
+485ms ââCondition #114 evaluated true (11ms)
+489ms ââCondition group #null evaluated true (state changed) (16ms)
+506ms ââExecution stage complete. (142ms)
+512ms âSetting up scheduled job for Sun, Dec 3 2017 @ 4:05:00 PM MST (in 72939.534s)
+612ms âEvent processed successfully (612ms)
sorry had to step away for a while.
when you put in the fadecolors manually do you still see the #nulls in the logs?
I have no Idea is there a way to activate it manually says this right now
Piston state: false
Last executed: 12/2/2017, 8:14:17 PM
Next scheduled: 12/3/2017, 3:51:00 PM
Devices used: 3
Memory used: 33% (32813 bytes)
change the time happens daily at to couple of mins from your current local time, save piston and then check in couple of mins if the lights start color fading
nope lights did not come on at all I have no idea why
Pause »
Piston category
Uncategorized
Quick facts
Piston state: true
Last executed: 12/2/2017, 8:25:59 PM
Next scheduled: 12/3/2017, 8:26:00 PM
Devices used: 3
Memory used: 42% (41949 bytes)
heres what the logs say
Logs
12/2/2017, 8:25:59 PM +105ms
+1ms âReceived event [Home].time = 1512275160000 with a delay of -896ms
+210ms âRunTime Analysis CS > 18ms > PS > 60ms > PE > 127ms > CE
+230ms âRuntime (66688 bytes) successfully initialized in 60ms (v0.2.0fe.20171109) (229ms)
+235ms ââExecution stage started
+250ms ââComparison (time) 73559349 happens_daily_at (time) 73560000 = true (4ms)
+252ms ââTime restriction check passed
+253ms ââCancelling condition #22âs schedulesâŠ
+254ms ââCondition #22 evaluated true (10ms)
+263ms ââCancelling statement #22âs schedulesâŠ
+267ms ââRequesting time schedule wake up at Sun, Dec 3 2017 @ 8:26:00 PM PST
+273ms ââCancelling condition #5âs schedulesâŠ
+274ms ââCondition group #5 evaluated true (state changed) (29ms)
+276ms ââCancelling statement #56âs schedulesâŠ
+282ms ââExecuted virtual command setVariable (3ms)
+287ms ââExecuted virtual command setVariable (3ms)
+308ms ââCalculating (string) 07/04/ + (string) 2017 >> (string) 07/04/2017
+317ms ââCalculating (decimal) 0.0 - (decimal) 7.0 >> (decimal) -7.0
+325ms ââCalculating (string) 07/04/ + (string) 2017 >> (string) 07/04/2017
+339ms ââComparison (date) 1512201600000 is_between (datetime) 1498546800000 ⊠(datetime) 1499238000000 = false (10ms)
+341ms ââCondition #27 evaluated false (51ms)
+343ms ââCondition group #6 evaluated false (state did not change) (53ms)
+355ms ââCalculating (string) 10/31/ + (string) 2017 >> (string) 10/31/2017
+362ms ââCalculating (decimal) 0.0 - (decimal) 7.0 >> (decimal) -7.0
+370ms ââCalculating (string) 10/31/ + (string) 2017 >> (string) 10/31/2017
+379ms ââComparison (date) 1512201600000 is_between (datetime) 1508828400000 ⊠(datetime) 1509433200000 = false (5ms)
+381ms ââCondition #29 evaluated false (34ms)
+382ms ââCondition group #13 evaluated false (state did not change) (35ms)
+392ms ââCalculating (string) 12/25/ + (string) 2017 >> (string) 12/25/2017
+398ms ââCalculating (decimal) 0.0 - (decimal) 21.0 >> (decimal) -21.0
+406ms ââCalculating (string) 12/25/ + (string) 2017 >> (string) 12/25/2017
+416ms ââComparison (date) 1512201600000 is_between (datetime) 1512374400000 ⊠(datetime) 1514793600000 = false (5ms)
+418ms ââCondition #30 evaluated false (33ms)
+419ms ââCondition group #17 evaluated false (state did not change) (34ms)
+434ms ââComparison (boolean) false is (boolean) true = false (1ms)
+435ms ââCancelling condition #114âs schedulesâŠ
+436ms ââCondition #114 evaluated false (14ms)
+437ms ââCancelling condition #nullâs schedulesâŠ
+438ms ââCondition group #null evaluated false (state changed) (16ms)
+441ms ââCancelling statement #46âs schedulesâŠ
+445ms ââExecuted virtual command setState (1ms)
+642ms ââCalculating (string) Empty device list == (string) playing >> (boolean) false
+648ms ââCalculating (boolean) false ! (boolean) false >> (boolean) true
+654ms ââExecuted virtual command setVariable (4ms)
+677ms ââCalculating (integer) 60 / (integer) 3 >> (integer) 20
+683ms ââExecuted virtual command setVariable (2ms)
+694ms ââCalculating (integer) 80 - (integer) 1 >> (integer) 79
+700ms ââCalculating (integer) 20 - (integer) 1 >> (integer) 19
+703ms ââCalculating (integer) 79 / (integer) 19 >> (integer) 4.1578947368
+709ms ââExecuted virtual command setVariable (3ms)
+715ms ââExecuted virtual command setVariable (3ms)
+724ms ââExecuted virtual command setVariable (4ms)
+745ms ââComparison (boolean) false is (boolean) false = true (2ms)
+746ms ââCancelling condition #38âs schedulesâŠ
+747ms ââCondition #38 evaluated true (20ms)
+750ms ââCancelling condition #48âs schedulesâŠ
+751ms ââCondition group #48 evaluated true (state changed) (24ms)
+753ms ââCancelling statement #36âs schedulesâŠ
+761ms ââCalculating (integer) 0 + (integer) 1 >> (integer) 1
+765ms ââExecuted virtual command setVariable (1ms)
+778ms ââComparison (boolean) true is (boolean) false = false (4ms)
+781ms ââCancelling condition #38âs schedulesâŠ
+782ms ââCondition #38 evaluated false (14ms)
+783ms ââCancelling condition #48âs schedulesâŠ
+784ms ââCondition group #48 evaluated false (state changed) (16ms)
+866ms ââComparison (boolean) false is (boolean) true = false (2ms)
+868ms ââCondition #45 evaluated false (81ms)
+869ms ââCondition group #51 evaluated false (state did not change) (83ms)
+879ms ââAn error occurred while executing the event: java.lang.NullPointerException: Cannot get property âvâ on null object
+882ms ââExecution stage complete. (651ms)
+893ms âSetting up scheduled job for Sun, Dec 3 2017 @ 8:26:00 PM PST (in 86400.003s)
+923ms âEvent processed successfully (924ms)
thanks. trying to find condition group #51 in the snapshot ⊠no luck yet.
please change the time again to couple of mins from your local time save and post the snapshot with trace on and the corresponding logs.
