Hi everyone! So I have two honeywell thermostats that I am controlling with two separate pistons each. One piston puts the thermostat on hold when I leave, and another piston resumes schedule when I arrive. I have two more pistons that do the same thing for another thermostat. All pistons seem to be functioning properly, however I keep getting a change failure notification form Honeywell for one of the thermostats. So to be clear, I get the change failure, but then I look in my ST app and both thermostats have changed appropriately. I’m not sure if it is because the pistons send out these requests multiple times, and the first one always fails, or what? Either way, the change failure notifications are annoying since they’re wrong all the time. I do want to keep the notices enabled, I’d just like it to work correctly. I’ve thought about it, and seems like it must be a piston or ST problem somehow, since Honeywell only sends these failures out when a change has actually occurred. I think it’s worth noting again that I have this setup on two identical thermostats but only one is sending out theses failure notices. Not sure where to look, and any help would be greatly appreciated! Thank you.
Thermostat gets put on hold when away
Thermostat does get put on hold, however I get a change failure notification for some reason from Honeywell.
**4) Post a Green Snapshot of the piston![image|45x37]![image|690x311]
(+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 108ms
+130ms â•‘Runtime (35407 bytes) successfully initialized in 14ms (v0.2.0e7.20170906) (129ms)
+131ms â•‘â•”Execution stage started
+146ms ║╚Execution stage complete. (15ms)
+154ms ╚Event processed successfully (154ms)
1/2/2018, 8:00:20 PM +818ms
+2ms ╔Received event [Jason’s iPhone].presence = present with a delay of 120ms
+147ms â•‘Runtime (35404 bytes) successfully initialized in 26ms (v0.2.0e7.20170906) (145ms)
+147ms â•‘â•”Execution stage started
+160ms ║╚Execution stage complete. (13ms)
+167ms ╚Event processed successfully (167ms)
1/2/2018, 6:23:51 PM +227ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 192ms
+121ms â•‘Runtime (35404 bytes) successfully initialized in 14ms (v0.2.0e7.20170906) (120ms)
+122ms â•‘â•”Execution stage started
+142ms ║╚Execution stage complete. (20ms)
+147ms ╚Event processed successfully (147ms)
1/2/2018, 4:31:12 PM +919ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 104ms
+148ms â•‘Runtime (35410 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (146ms)
+149ms â•‘â•”Execution stage started
+200ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (25ms)
+202ms ║╚Execution stage complete. (53ms)
+209ms ╚Event processed successfully (208ms)
1/2/2018, 4:23:34 PM +897ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 102ms
+127ms â•‘Runtime (35408 bytes) successfully initialized in 18ms (v0.2.0e7.20170906) (126ms)
+128ms â•‘â•”Execution stage started
+147ms ║╚Execution stage complete. (20ms)
+157ms ╚Event processed successfully (157ms)
1/2/2018, 4:08:51 PM +909ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 135ms
+161ms â•‘Runtime (35406 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (159ms)
+162ms â•‘â•”Execution stage started
+178ms ║╚Execution stage complete. (16ms)
+187ms ╚Event processed successfully (186ms)
1/2/2018, 4:01:57 PM +47ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 92ms
+126ms â•‘Runtime (35401 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (124ms)
+127ms â•‘â•”Execution stage started
+138ms ║╚Execution stage complete. (12ms)
+145ms ╚Event processed successfully (145ms)
1/2/2018, 3:04:47 PM +309ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 119ms
+415ms â•‘Piston waited at a semaphore for 262ms
+417ms â•‘Runtime (35475 bytes) successfully initialized in 287ms (v0.2.0e7.20170906) (414ms)
+417ms â•‘â•”Execution stage started
+731ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (45ms)
+733ms ║╚Execution stage complete. (316ms)
+739ms ╚Event processed successfully (739ms)
1/2/2018, 3:04:47 PM +304ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 111ms
+123ms â•‘Runtime (35410 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (122ms)
+124ms â•‘â•”Execution stage started
+170ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (22ms)
+173ms ║╚Execution stage complete. (49ms)
+179ms ╚Event processed successfully (179ms)
1/2/2018, 3:03:23 PM +409ms
+2ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 117ms
+136ms â•‘Runtime (35405 bytes) successfully initialized in 41ms (v0.2.0e7.20170906) (133ms)
+136ms â•‘â•”Execution stage started
+156ms ║╚Execution stage complete. (19ms)
+161ms ╚Event processed successfully (161ms)
1/2/2018, 2:41:09 PM +782ms
+16ms ╔Received event [Jason’s iPhone].presence = present with a delay of 87ms
+169ms â•‘Runtime (35404 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (144ms)
+172ms â•‘â•”Execution stage started
+183ms ║╚Execution stage complete. (14ms)
+193ms ╚Event processed successfully (193ms)
1/2/2018, 1:37:27 PM +528ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 112ms
+178ms â•‘Runtime (35405 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (176ms)
+179ms â•‘â•”Execution stage started
+198ms ║╚Execution stage complete. (19ms)
+252ms ╚Event processed successfully (252ms)
1/2/2018, 10:31:53 AM +580ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 116ms
+132ms â•‘Runtime (35403 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (130ms)
+133ms â•‘â•”Execution stage started
+149ms ║╚Execution stage complete. (17ms)
+303ms ╚Event processed successfully (303ms)
1/2/2018, 8:31:39 AM +617ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 93ms
+110ms â•‘Runtime (35406 bytes) successfully initialized in 17ms (v0.2.0e7.20170906) (108ms)
+110ms â•‘â•”Execution stage started
+126ms ║╚Execution stage complete. (16ms)
+132ms ╚Event processed successfully (132ms)
1/1/2018, 7:17:46 PM +4ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 163ms
+206ms â•‘Runtime (35404 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (204ms)
+207ms â•‘â•”Execution stage started
+218ms ║╚Execution stage complete. (12ms)
+225ms ╚Event processed successfully (225ms)
1/1/2018, 6:17:17 PM +199ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 121ms
+103ms â•‘Runtime (35404 bytes) successfully initialized in 14ms (v0.2.0e7.20170906) (101ms)
+103ms â•‘â•”Execution stage started
+447ms ║╚Execution stage complete. (344ms)
+454ms ╚Event processed successfully (454ms)
1/1/2018, 5:01:23 PM +823ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 155ms
+125ms â•‘Runtime (35408 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (123ms)
+126ms â•‘â•”Execution stage started
+180ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (31ms)
+182ms ║╚Execution stage complete. (56ms)
+196ms ╚Event processed successfully (196ms)
1/1/2018, 5:01:18 PM +609ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 107ms
+110ms â•‘Runtime (35410 bytes) successfully initialized in 15ms (v0.2.0e7.20170906) (108ms)
+155ms ║╚Execution stage complete. (45ms)
+163ms ╚Event processed successfully (163ms)
1/1/2018, 4:06:04 PM +251ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 126ms
+107ms â•‘Runtime (35406 bytes) successfully initialized in 11ms (v0.2.0e7.20170906) (106ms)
+108ms â•‘â•”Execution stage started
+421ms ║╚Execution stage complete. (313ms)
+427ms ╚Event processed successfully (427ms)
1/1/2018, 2:58:57 PM +23ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 116ms
+138ms â•‘Runtime (35410 bytes) successfully initialized in 29ms (v0.2.0e7.20170906) (136ms)
+138ms â•‘â•”Execution stage started
+153ms ║╚Execution stage complete. (15ms)
+159ms ╚Event processed successfully (158ms)
12/31/2017, 3:17:46 PM +66ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 245ms
+139ms â•‘Runtime (35406 bytes) successfully initialized in 29ms (v0.2.0e7.20170906) (137ms)
+140ms â•‘â•”Execution stage started
+155ms ║╚Execution stage complete. (14ms)
+162ms ╚Event processed successfully (161ms)
12/31/2017, 3:11:26 PM +472ms
+0ms ╔Received event [Jason’s iPhone].presence = present with a delay of 95ms
+423ms â•‘Runtime (35402 bytes) successfully initialized in 184ms (v0.2.0e7.20170906) (421ms)
+423ms â•‘â•”Execution stage started
+435ms ║╚Execution stage complete. (12ms)
+442ms ╚Event processed successfully (443ms)
12/31/2017, 3:02:59 PM +195ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 133ms
+131ms â•‘Runtime (35410 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (129ms)
+179ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (26ms)
+181ms ║╚Execution stage complete. (50ms)
+187ms ╚Event processed successfully (187ms)
12/31/2017, 10:32:05 AM +73ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 110ms
+132ms â•‘Runtime (35404 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (130ms)
+389ms ║╚Execution stage complete. (256ms)
+395ms ╚Event processed successfully (396ms)
12/31/2017, 9:57:28 AM +918ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 249ms
+149ms â•‘Runtime (35410 bytes) successfully initialized in 27ms (v0.2.0e7.20170906) (147ms)
+202ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (31ms)
+204ms ║╚Execution stage complete. (55ms)
+223ms ╚Event processed successfully (224ms)
12/31/2017, 9:22:38 AM +760ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 113ms
+140ms â•‘Runtime (35404 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (138ms)
+159ms ║╚Execution stage complete. (19ms)
+165ms ╚Event processed successfully (165ms)
12/31/2017, 8:18:37 AM +830ms
+125ms â•‘Runtime (35410 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (123ms)
+504ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (353ms)
+508ms ║╚Execution stage complete. (383ms)
+521ms ╚Event processed successfully (521ms)
12/30/2017, 4:46:36 PM +406ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 316ms
+136ms â•‘Runtime (35404 bytes) successfully initialized in 35ms (v0.2.0e7.20170906) (134ms)
+137ms â•‘â•”Execution stage started
+159ms ║╚Execution stage complete. (23ms)
+166ms ╚Event processed successfully (166ms)
12/30/2017, 3:29:29 PM +352ms
+136ms â•‘Runtime (35408 bytes) successfully initialized in 27ms (v0.2.0e7.20170906) (133ms)
+212ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (54ms)
+214ms ║╚Execution stage complete. (78ms)
+221ms ╚Event processed successfully (220ms)
12/30/2017, 3:29:28 PM +317ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 211ms
+119ms â•‘Runtime (35402 bytes) successfully initialized in 27ms (v0.2.0e7.20170906) (117ms)
+120ms â•‘â•”Execution stage started
+132ms ║╚Execution stage complete. (12ms)
+138ms ╚Event processed successfully (138ms)
12/30/2017, 3:27:24 PM +872ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 127ms
+116ms â•‘Runtime (35410 bytes) successfully initialized in 27ms (v0.2.0e7.20170906) (114ms)
+116ms â•‘â•”Execution stage started
+180ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (41ms)
+182ms ║╚Execution stage complete. (66ms)
+188ms ╚Event processed successfully (188ms)
12/30/2017, 12:57:29 PM +167ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 174ms
+100ms â•‘Runtime (35405 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (98ms)
+100ms â•‘â•”Execution stage started
+118ms ║╚Execution stage complete. (18ms)
+126ms ╚Event processed successfully (126ms)
12/30/2017, 11:03:15 AM +533ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 121ms
+207ms â•‘Runtime (35404 bytes) successfully initialized in 115ms (v0.2.0e7.20170906) (204ms)
+222ms ║╚Execution stage complete. (15ms)
+228ms ╚Event processed successfully (228ms)
12/30/2017, 9:43:50 AM +763ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 117ms
+135ms â•‘Runtime (35407 bytes) successfully initialized in 41ms (v0.2.0e7.20170906) (132ms)
+135ms â•‘â•”Execution stage started
+175ms ║╚Execution stage complete. (40ms)
+185ms ╚Event processed successfully (185ms)
12/29/2017, 4:31:28 PM +716ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 159ms
+113ms â•‘Runtime (35403 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (111ms)
+114ms â•‘â•”Execution stage started
+127ms ║╚Execution stage complete. (12ms)
+135ms ╚Event processed successfully (134ms)
12/29/2017, 4:17:17 PM +661ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 114ms
+116ms â•‘Runtime (35407 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (114ms)
+117ms â•‘â•”Execution stage started
+133ms ║╚Execution stage complete. (16ms)
+140ms ╚Event processed successfully (139ms)
12/29/2017, 3:30:10 PM +9ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 172ms
+96ms â•‘Runtime (35403 bytes) successfully initialized in 12ms (v0.2.0e7.20170906) (95ms)
+97ms â•‘â•”Execution stage started
+110ms ║╚Execution stage complete. (13ms)
12/29/2017, 2:26:45 PM +481ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 197ms
+122ms â•‘Runtime (35407 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (119ms)
+137ms ║╚Execution stage complete. (15ms)
12/29/2017, 1:50:16 PM +792ms
+2ms ╔Received event [Jason’s iPhone].presence = present with a delay of 115ms
+166ms â•‘Runtime (35404 bytes) successfully initialized in 21ms (v0.2.0e7.20170906) (164ms)
+167ms â•‘â•”Execution stage started
+180ms ║╚Execution stage complete. (13ms)
12/29/2017, 1:05:41 PM +366ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 209ms
+105ms â•‘Runtime (35405 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (103ms)
+105ms â•‘â•”Execution stage started
+123ms ║╚Execution stage complete. (18ms)
+221ms ╚Event processed successfully (221ms)
12/29/2017, 10:02:55 AM +21ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 125ms
+122ms â•‘Runtime (35403 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (121ms)
+123ms â•‘â•”Execution stage started
+138ms ║╚Execution stage complete. (15ms)
+144ms ╚Event processed successfully (145ms)
12/29/2017, 8:51:17 AM +743ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 99ms
+129ms â•‘Runtime (35406 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (127ms)
+130ms â•‘â•”Execution stage started
+145ms ║╚Execution stage complete. (16ms)
+151ms ╚Event processed successfully (152ms)
12/28/2017, 6:06:40 PM +477ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 110ms
+186ms â•‘Runtime (35404 bytes) successfully initialized in 22ms (v0.2.0e7.20170906) (184ms)
+186ms â•‘â•”Execution stage started
+197ms ║╚Execution stage complete. (11ms)
+203ms ╚Event processed successfully (203ms)
12/28/2017, 4:01:39 PM +366ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 111ms
+135ms â•‘Runtime (35404 bytes) successfully initialized in 33ms (v0.2.0e7.20170906) (133ms)
+155ms ║╚Execution stage complete. (20ms)
12/28/2017, 3:19:35 PM +146ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 161ms
+120ms â•‘Runtime (35410 bytes) successfully initialized in 29ms (v0.2.0e7.20170906) (118ms)
+121ms â•‘â•”Execution stage started
+175ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (30ms)
+177ms ║╚Execution stage complete. (56ms)
+183ms ╚Event processed successfully (183ms)
12/28/2017, 2:15:32 PM +221ms
+0ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 97ms
+101ms â•‘Runtime (35407 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (100ms)
+102ms â•‘â•”Execution stage started
+118ms ║╚Execution stage complete. (17ms)
+125ms ╚Event processed successfully (125ms)
12/28/2017, 1:48:32 PM +888ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 97ms
+144ms â•‘Runtime (35405 bytes) successfully initialized in 17ms (v0.2.0e7.20170906) (141ms)
+144ms â•‘â•”Execution stage started
+158ms ║╚Execution stage complete. (14ms)
+166ms ╚Event processed successfully (165ms)
12/28/2017, 10:53:46 AM +24ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 149ms
+141ms â•‘Runtime (35410 bytes) successfully initialized in 24ms (v0.2.0e7.20170906) (140ms)
+141ms â•‘â•”Execution stage started
12/28/2017, 10:00:52 AM +523ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 268ms
+121ms â•‘Runtime (35406 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (119ms)
+148ms ╚Event processed successfully (148ms)
12/28/2017, 9:05:22 AM +340ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 94ms
+115ms â•‘Runtime (35401 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (113ms)
+115ms â•‘â•”Execution stage started
+126ms ║╚Execution stage complete. (10ms)
+131ms ╚Event processed successfully (131ms)
12/28/2017, 8:46:14 AM +653ms
+251ms â•‘Runtime (35411 bytes) successfully initialized in 143ms (v0.2.0e7.20170906) (248ms)
+251ms â•‘â•”Execution stage started
+322ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (48ms)
+324ms ║╚Execution stage complete. (73ms)
+435ms ╚Event processed successfully (435ms)
12/28/2017, 8:46:14 AM +661ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 114ms
+223ms â•‘Runtime (35411 bytes) successfully initialized in 124ms (v0.2.0e7.20170906) (222ms)
+224ms â•‘â•”Execution stage started
+284ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (38ms)
+286ms ║╚Execution stage complete. (62ms)
+293ms ╚Event processed successfully (293ms)
12/27/2017, 7:15:04 PM +956ms
+0ms ╔Received event [Christy’s iPhone].presence = present with a delay of 79ms
+102ms â•‘Runtime (35403 bytes) successfully initialized in 18ms (v0.2.0e7.20170906) (100ms)
+120ms ║╚Execution stage complete. (18ms)
+127ms ╚Event processed successfully (127ms)
12/27/2017, 7:03:00 PM +698ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 91ms
+119ms â•‘Runtime (35409 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (118ms)
+247ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (105ms)
+249ms ║╚Execution stage complete. (129ms)
+256ms ╚Event processed successfully (255ms)
12/27/2017, 6:32:26 PM +278ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 111ms
+139ms â•‘Runtime (35408 bytes) successfully initialized in 32ms (v0.2.0e7.20170906) (137ms)
+139ms â•‘â•”Execution stage started
+156ms ║╚Execution stage complete. (17ms)
12/27/2017, 4:30:42 PM +521ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 128ms
+124ms â•‘Runtime (35406 bytes) successfully initialized in 26ms (v0.2.0e7.20170906) (122ms)
+125ms â•‘â•”Execution stage started
+139ms ║╚Execution stage complete. (14ms)
12/27/2017, 3:25:24 PM +604ms
+0ms ╔Received event [Jason’s iPhone].presence = present with a delay of 212ms
+94ms â•‘Runtime (35402 bytes) successfully initialized in 12ms (v0.2.0e7.20170906) (92ms)
+94ms â•‘â•”Execution stage started
+105ms ║╚Execution stage complete. (11ms)
+112ms ╚Event processed successfully (112ms)
12/27/2017, 3:15:19 PM +172ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 151ms
+132ms â•‘Runtime (35410 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (129ms)
+132ms â•‘â•”Execution stage started
+198ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (44ms)
+200ms ║╚Execution stage complete. (68ms)
+207ms ╚Event processed successfully (206ms)
12/27/2017, 1:43:33 PM +665ms
+1ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 91ms
+134ms â•‘Runtime (35404 bytes) successfully initialized in 50ms (v0.2.0e7.20170906) (133ms)
+152ms ║╚Execution stage complete. (17ms)
12/27/2017, 12:25:21 PM +143ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 107ms
+116ms â•‘Runtime (35403 bytes) successfully initialized in 20ms (v0.2.0e7.20170906) (114ms)
+128ms ║╚Execution stage complete. (12ms)
12/27/2017, 11:52:55 AM +817ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 141ms
+136ms â•‘Runtime (35407 bytes) successfully initialized in 28ms (v0.2.0e7.20170906) (134ms)
+153ms ║╚Execution stage complete. (17ms)
12/26/2017, 8:07:23 PM +472ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 102ms
+107ms â•‘Runtime (35403 bytes) successfully initialized in 12ms (v0.2.0e7.20170906) (106ms)
+125ms ║╚Execution stage complete. (16ms)
+132ms ╚Event processed successfully (133ms)
12/26/2017, 7:46:00 PM +695ms
+0ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 91ms
+97ms â•‘Runtime (35406 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (96ms)
+98ms â•‘â•”Execution stage started
+116ms ╚Event processed successfully (117ms)
12/26/2017, 1:34:19 PM +719ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 96ms
+118ms â•‘Runtime (35402 bytes) successfully initialized in 23ms (v0.2.0e7.20170906) (117ms)
+119ms â•‘â•”Execution stage started
+132ms ║╚Execution stage complete. (13ms)
12/26/2017, 1:01:25 PM +625ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 83ms
+93ms â•‘Runtime (35406 bytes) successfully initialized in 13ms (v0.2.0e7.20170906) (92ms)
+107ms ║╚Execution stage complete. (14ms)
+113ms ╚Event processed successfully (113ms)
12/26/2017, 7:17:10 AM +842ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 108ms
+143ms â•‘Runtime (35404 bytes) successfully initialized in 30ms (v0.2.0e7.20170906) (140ms)
+143ms â•‘â•”Execution stage started
+154ms ║╚Execution stage complete. (11ms)
+162ms ╚Event processed successfully (162ms)
12/25/2017, 5:43:37 PM +334ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 108ms
+89ms â•‘Runtime (35404 bytes) successfully initialized in 12ms (v0.2.0e7.20170906) (87ms)
+89ms â•‘â•”Execution stage started
+107ms ║╚Execution stage complete. (18ms)
+116ms ╚Event processed successfully (116ms)
12/25/2017, 2:37:05 PM +988ms
+0ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 84ms
+106ms â•‘Runtime (35409 bytes) successfully initialized in 18ms (v0.2.0e7.20170906) (105ms)
+107ms â•‘â•”Execution stage started
+316ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (189ms)
+318ms ║╚Execution stage complete. (211ms)
+325ms ╚Event processed successfully (326ms)
12/25/2017, 1:01:18 PM +356ms
+2ms ╔Received event [Christy’s iPhone].presence = present with a delay of 344ms
+119ms â•‘Runtime (35404 bytes) successfully initialized in 19ms (v0.2.0e7.20170906) (117ms)
+138ms ║╚Execution stage complete. (18ms)
12/25/2017, 10:05:27 AM +702ms
+1ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 103ms
+116ms â•‘Runtime (35410 bytes) successfully initialized in 21ms (v0.2.0e7.20170906) (114ms)
+177ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (37ms)
+178ms ║╚Execution stage complete. (62ms)
+288ms ╚Event processed successfully (288ms)
12/25/2017, 8:49:51 AM +403ms
+1ms ╔Received event [Christy’s iPhone].presence = present with a delay of 101ms
+123ms â•‘Runtime (35404 bytes) successfully initialized in 28ms (v0.2.0e7.20170906) (120ms)
+140ms ║╚Execution stage complete. (17ms)
12/25/2017, 8:11:31 AM +330ms
+2ms ╔Received event [Christy’s iPhone].presence = not present with a delay of 109ms
+127ms â•‘Runtime (35410 bytes) successfully initialized in 29ms (v0.2.0e7.20170906) (125ms)
+189ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (39ms)
+191ms ║╚Execution stage complete. (64ms)
+197ms ╚Event processed successfully (197ms)
12/25/2017, 6:33:38 AM +897ms
+125ms â•‘Runtime (35405 bytes) successfully initialized in 26ms (v0.2.0e7.20170906) (124ms)
+142ms ║╚Execution stage complete. (17ms)
12/24/2017, 7:27:42 PM +423ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 119ms
+125ms â•‘Runtime (35404 bytes) successfully initialized in 31ms (v0.2.0e7.20170906) (124ms)
+136ms ║╚Execution stage complete. (10ms)
+143ms ╚Event processed successfully (142ms)
12/24/2017, 7:21:54 PM +936ms
+116ms â•‘Runtime (35403 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (114ms)
+134ms ║╚Execution stage complete. (18ms)
+144ms ╚Event processed successfully (144ms)
12/24/2017, 3:01:45 PM +353ms
+2ms â•”Received event [Home].test = 1514152905333 with a delay of 15ms
+150ms â•‘Runtime (35396 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (145ms)
+152ms â•‘â•”Execution stage started
+459ms â•‘â•‘Executed [HOUSE].setHeatingSetpoint (222ms)
+473ms ║╚Execution stage complete. (323ms)
+485ms ╚Event processed successfully (486ms)
12/24/2017, 2:56:31 PM +532ms
+6ms ╔Starting piston… (v0.2.0e7.20170906)
+247ms ║╔Subscribing to devices…
+324ms ║║Subscribing to Jason’s iPhone.presence…
+340ms ║║Subscribing to Christy’s iPhone.presence…
+468ms ║║Subscribing to HOUSE…
+469ms ║╚Finished subscribing (235ms)
+591ms ╚Piston successfully started (588ms)
12/24/2017, 2:41:15 PM +790ms
+1ms ╔Starting piston… (v0.2.0e7.20170906)
+152ms ║╔Subscribing to devices…
+159ms ║║Subscribing to Jason’s iPhone.presence…
+166ms ║║Subscribing to Christy’s iPhone.presence…
+220ms ║║Subscribing to HOUSE…
+221ms ║╚Finished subscribing (72ms)
+277ms ╚Piston successfully started (276ms)
12/24/2017, 2:36:45 PM +136ms
+2ms ╔Received event [Jason’s iPhone].presence = not present with a delay of 128ms
+128ms â•‘Runtime (35245 bytes) successfully initialized in 25ms (v0.2.0e7.20170906) (126ms)
+129ms â•‘â•”Execution stage started
+146ms ║╚Execution stage complete. (18ms)
+152ms ╚Event processed successfully (152ms)
12/23/2017, 8:09:09 PM +46ms
+1ms ╔Received event [Jason’s iPhone].presence = present with a delay of 251ms
+252ms â•‘Runtime (35244 bytes) successfully initialized in 48ms (v0.2.0e7.20170906) (250ms)
+253ms â•‘â•”Execution stage started
