When sleeping mode is active, the temperature changes do not occur
(When sleeping mode is active, the goal is to make the bedroom a certain temp
(The logs say the setcooling point and sethearing point commands happen and that’s great. The ST log for the thermostat shows it received it. But the thermostat doesn’t change. It’s a Honeywell so there may be some need to workaround but all my other pistons dealing with temp work fine (leaving and arriving home for example)
