My piston defines a datetime variable called LastNotice and does not assign it a value. In the local variables list, it displays that this variable is “Invalid Date” in light grey text. It’s not null or blank.
I want to compare $now to this variable to prevent my piston from running too often. I need some way of initializing it once, because then it will retain the value and run properly.
I’ve tried a few ways of doing this, comparing the integer of $now and my variable which hasn’t been set. The log tells me that it compared two integers, which baffles me because how is the value for my LastNotice variable derived?
I can’t seem to compare it to null or a blank value either, since it always comes up with some integer value during these comparisons. So I haven’t been able to check if the variable doesn’t have a value, since it somehow does when the piston is run.
|+132ms|║║Calculating (integer) 1474806400 - (integer) 1474806391 >> (integer) 9|
|+135ms|║║Comparison (integer) 9 is_less_than (integer) 30000 = true (1ms)|
|+136ms|║║Condition #41 evaluated true (10ms)|
|+137ms|║║Condition group #38 evaluated true (state did not change) (12ms)|
|+139ms|║║Cancelling statement #39's schedules...|
