It is possible to remove this argument? I believe it is causing the function to not run correctly. When I uncheck the “only when in this mode” selection, it doesnt remove “Only while”.
How can I remove the (only while)?
pcgirl65
It isn’t doing anything because you don’t have anything in the condition like only while ‘Home’. It is blank.
guxdude
I have found once I have put that in there is no way to remove it except to recreate the command without it. It should work the same so not sure why it would cause you a problem. Perhaps you could post the full piston and describe what is not working.
pete
I’ve found that the function does not run unless it remove it as well. I feel like unchecking it from the dropdown menu should delete it.
