How do I find # of minutes between $sunset and 10:00 PM?
I’ve got a piston I’m working on that requires me to have an expression that will tell me how many minutes there are between $sunset and 10:00 PM.
I’ve tried 10,000 different ways and I can’t seem to come up with the answer. I know what the answer should be, but there’s no way I can make an expression come up with it.
Any help out there?
How about:
(time('10:00:00 PM CST')-time($sunset))/1000/60
Obviously, use your timezone in there…
set variable (intMinutes) = ((addhours($nextMidnight, -2) - $sunset) / 60000);
Oh, I like that. Gets around the date complication nicely.
Thanks. I helped someone make a piston where they wanted to turn on a light at a random time between sunset and 11PM. Took a few iterations, but that’s what eventually worked out very well.
Once you have that number…you can then do something like:
wait randomly between 0 and intMinutes minutes
Turn on light
wait randomly between 10 and 20 minutes
turn off light
This works perfectly! Thanks so much. Very elegant solution.
this one works with time only:
(time(‘22:00’) - time($sunset)) / 60000
