How do I reduce/shorten this one line of code?
I feel like I should know this, but I am drawing a blank at the moment…
I added a new line of code to an old piston, and now the piston is too large to save.
To create space, I am trying to streamline the following code:
Set variable x = max(a[0],a[1],a[2],a[3],a[4],a[5],a[6],a[7],a[8],a[9])
Can anyone please help?
My numbers actually go up to a[69], but if I can reduce the above, I can apply what I learn to the larger issue.
Thanks in advance.
Can you sort the array and take either the first or last element (depending on how its sorted).
Thanks for the input. Unfortunately, I cannot sort this array because I need them to retain the precise order they are in to draw my graph accurately.
I don’t have time to try this now, but what if you did something like:
define variable maxSoFar
Set variable maxSoFar = a[0]
For x between 1 and 69
Set variable maxSoFar = max (maxSoFar,a[x])
x == x+1
I don’t know if that’ll actually save you code space or not but it’s all my foggy brain can come up with at the moment.
You could alternatively do…
define variable maxSoFar = a[0]
define x = 1
repeat
  if  a[x] > maxSoFar then maxSoFar = a[x]
  x = x+1
until x=69
Both should work.
