Is it possible to cancel a timer (invoked using an “every” block of code) once it has started?
I have created a simple piston with only an “every” block inside it, something like “every 15 minutes, do this…”. This is based on the suggestion by @Mike1616 in this post:
No matter what I have tried so far, I just can’t get the timer to cancel its scheduled jobs / tasks once it has started. The timer even laughs in the face of the “Cancel all pending tasks” command (despite the console logs stating that jobs / tasks have been cancelled, the timer’s countdown clock on the Dashboard still continues to count down happily, and the Quick Facts show that there is a next scheduled task).
I want to be able to invoke the timer (using an “every” block) and then be able to kill that timer altogether through whatever means (from another piston, inside the timer piston itself, global variable switching etc.) so that it’s countdown clock completely ceases and desists, until I decide to invoke the timer piston again at a later time.
Ideally, I don’t want to go down the route of pausing / resuming the timer piston just to stop / restart its timer. It also seems like a no-no to nest an “every” timer inside an IF condition (I get a banner warning when attempting to do so).
I am not able to cancel the timer once it has started. It seems invincible.
No green snapshot of a piston included, as the timer piston is so simple, and I just want to see whether or not the concept of cancelling an “every” timer is at all possible.
