Looking to capture the state of some lighting devices, indicate an alarm change, and then return to that previous state. In the process there of learning about how capturing state function works.
To capture the state of the devices, indicate a an alarm change and return to previous state
Just want to make sure the syntax is correct and piston has been built correctly.
n.a.
