How to Clear Out a Boolean Variable
I’m trying to clear a boolean Variable (set to " ", not just set to false). Can can that be done? This is for a virtual thermostat I’m working on. I want to be able to adjust my Simulated Thermostat so that if I set it to 50 or 70, the program takes over, if it is set to anythign else, the Thermostat controls it. This is to control an appliance switch.
Set Variable {Programmatic} = [blank], should return “boolean Programmatic; /* */”
It keeps the last setting /* false */
(UPLOAD YOUR IMAGE H
ERE)
1/10/2018, 11:15:28 AM +760ms +1ms ╔Received event [Home].time = 1515600929361 with a delay of -601ms +234ms ║RunTime Analysis CS > 43ms > PS > 96ms > PE > 95ms > CE +238ms ║Runtime (61520 bytes) successfully initialized in 96ms (v0.2.101.20171227) (236ms) +239ms ║╔Execution stage started +248ms ║║Cancelling statement #142's schedules... +1900ms ║║Executed physical command [Master Bedroom TStat - Virtual].setTemperature([60]) (1639ms) +1901ms ║║Executed [Master Bedroom TStat - Virtual].setTemperature (1641ms) +1911ms ║║Comparison (enum) heat is_not (string) off = true (2ms) +1913ms ║║Condition #121 evaluated true (9ms) +1924ms ║║Comparison (decimal) 69.0 is_equal_to (decimal) 70.0 = false (1ms) +1925ms ║║Condition #150 evaluated false (11ms) +1935ms ║║Comparison (decimal) 69.0 is_equal_to (integer) 50 = false (1ms) +1936ms ║║Condition #151 evaluated false (11ms) +1937ms ║║Condition group #149 evaluated false (state did not change) (24ms) +1938ms ║║Condition group #117 evaluated false (state did not change) (34ms) +1940ms ║║Cancelling statement #118's schedules... +1946ms ║║Executed virtual command setVariable (3ms) +1952ms ║║Comparison (boolean) false is_not (boolean) true = true (2ms) +1953ms ║║Condition #157 evaluated true (5ms) +1969ms ║║Comparison (decimal) 60.0 is_less_than_or_equal_to (decimal) 69.0 = true (1ms) +1970ms ║║Condition #158 evaluated true (16ms) +1971ms ║║Condition group #152 evaluated true (state did not change) (23ms) +1973ms ║║Cancelling statement #155's schedules... +1978ms ║║Executed virtual command setVariable (3ms) +1984ms ║║Comparison (string) :7cbc16b5a791742beb269d87212ee95c: is_any_of (string) :7cbc16b5a791742beb269d87212ee95c:,:6370f13e157a8bd6303a747a552bd516:,:6392e11996141424120e5e0142441c3d: = true (1ms) +1986ms ║║Condition #23 evaluated true (5ms) +1991ms ║║Comparison (integer) 1 is_greater_than_or_equal_to (integer) 2 = false (1ms) +1992ms ║║Condition #69 evaluated false (5ms) +1995ms ║║Comparison (string) :7cbc16b5a791742beb269d87212ee95c: changes = false (0ms) +1995ms ║║Condition #70 evaluated false (2ms) +1996ms ║║Condition group #68 evaluated false (state did not change) (9ms) +1997ms ║║Condition group #2 evaluated false (state did not change) (16ms) +2003ms ║║Comparison (string) :7cbc16b5a791742beb269d87212ee95c: is_any_of (string) :7cbc16b5a791742beb269d87212ee95c:,:6370f13e157a8bd6303a747a552bd516:,:6392e11996141424120e5e0142441c3d: = true (2ms) +2004ms ║║Condition #45 evaluated true (5ms) +2009ms ║║Comparison (integer) 1 is_greater_than_or_equal_to (integer) 2 = false (1ms) +2011ms ║║Condition #72 evaluated false (5ms) +2013ms ║║Comparison (string) :7cbc16b5a791742beb269d87212ee95c: changes = false (0ms) +2014ms ║║Condition #73 evaluated false (2ms) +2014ms ║║Condition group #71 evaluated false (state did not change) (9ms) +2015ms ║║Condition group #24 evaluated false (state did not change) (16ms) +2022ms ║║Comparison (integer) 1 is_less_than (integer) 2 = true (2ms) +2023ms ║║Condition #82 evaluated true (6ms) +2027ms ║║Comparison (dynamic) Home Day is (string) Home Day = true (1ms) +2028ms ║║Condition #86 evaluated true (4ms) +2029ms ║║Condition group #77 evaluated true (state did not change) (12ms) +2031ms ║║Cancelling statement #80's schedules... +2035ms ║║Calculating (integer) 1 + (integer) 1 >> (integer) 2 +2041ms ║║Executed virtual command setVariable (4ms) +2045ms ║║Comparison (string) :7cbc16b5a791742beb269d87212ee95c: changes = false (1ms) +2046ms ║║Condition #106 evaluated false (3ms) +2047ms ║║Condition group #103 evaluated false (state did not change) (4ms) +2052ms ║║Comparison (boolean) true is (boolean) true = true (1ms) +2054ms ║║Condition #148 evaluated true (4ms) +2054ms ║║Condition group #136 evaluated true (state did not change) (5ms) +2056ms ║║Cancelling statement #161's schedules... +2065ms ║║Skipped execution of physical command [Master Bedroom Switch].on([]) because it would make no change to the device. (3ms) +2065ms ║║Executed [Master Bedroom Switch].on (5ms) +2068ms ║║Cancelling statement #163's schedules... +2075ms ║║Error retrieving JSON data part null +2079ms ║║Executed virtual command setVariable (3ms) +2082ms ║╚Execution stage complete. (1844ms) +2083ms ║Setting up scheduled job for Wed, Jan 10 2018 @ 11:16:29 AM EST (in 58.518s) +2092ms ╚Event processed successfully (2092ms) 1/10/2018, 11:15:05 AM +59ms +4ms ╔Received event [Home].test = 1515600905053 with a delay of 2ms +256ms ║RunTime Analysis CS > 25ms > PS > 135ms > PE > 99ms > CE +267ms ║Runtime (61519 bytes) successfully initialized in 135ms (v0.2.101.20171227) (261ms) +271ms ║╔Execution stage started +339ms ║╚Execution stage complete. (69ms) +352ms ║Setting up scheduled job for Wed, Jan 10 2018 @ 11:15:29 AM EST (in 23.953s) +364ms ╚Event processed successfully (365ms)
By the way, this piston is derived from the very awesome TempThing
https://community.webcore.co/t/tempthing-an-intelligent-thermostat-controller/2311/5
Assuming you have good reason to require three states rather than two, there is no way to set a boolean back to unset because the value will always be coerced to true or false. You may instead consider using numbers like -1 0 and 1, or a string variable with values that webCoRE understands as boolean, like "true" and "false" or "on" and "off". These strings are treated as boolean true and false:
(expression) bool('off') »»» (boolean) false
(expression) bool('on') »»» (boolean) true
(expression) 'off' && 'on' »»» (boolean) false
(expression) 'off' || 'on' »»» (boolean) true
I ran into the same thing a while back… not being a coder/programmer kind of got stuck and ended up using strings ‘y’ and ‘n’, I didn’t know about the on, off, true, and false. Thanks for that. :smiley:
For reference, here is the current full list of strings that behave as true and false values:
true
  • "1"
  • "true"
  • "on"
  • "open"
  • "locked"
  • "active"
  • "wet"
  • "detected"
  • "present"
  • "occupied"
  • "muted"
  • "sleeping"
false
  • "0"
  • "false"
  • "off"
  • "closed"
  • "unlocked"
  • "inactive"
  • "dry"
  • "clear"
  • "not detected"
  • "not present"
  • "not occupied"
  • "unmuted"
  • "not sleeping"
  • "null"
