Device Health is rather arcane. Getting ST to cough up as to how it is meant to be working has always been largely fruitless.
The meaning of the ONLINE/OFFLINE status is rather device dependent anyway. For hub connected devices OFFLINE represents an absence of expected activity. For sleepy end devices that don’t send out regular reports the chances are the status is simply that of the hub, while if a device reports daily it may take a two days before SmartThings considers it offline. Once a device is OFFLINE it might not be considered ONLINE again until manual action is taken.
As far as I know it isn’t possible to use the healthStatus or DeviceWatch-DeviceStatus attributes to monitor hub connected devices anymore (that went several months ago). The healthStatus attribute might perhaps still work for cloud connected devices using the schema integration as that was how the status was meant to be communicated.
In webCoRE the $status attribute should reflect the same status shown in the IDE but it can’t be triggered on.
In the current environment, not the legacy environment of the IDE and webCoRE, the status is available via the REST API and can be subscribed to and that will be the area that is evolving.
