I can’t seem to edit the “green” text when in edit mode for the script. This was a borrowed piston for “Welcome Sound”, and I need to change the description. Thoughts?
that did not work. if I click on the green area nothing happens. Not sure what you mean by “title” is the same of what I’m thinking. Is it possible that the creator locked it?
You should be able to click on the piston title (the line that contains the piston name) at the very top, in edit mode.
Those are comments, not executable code.
/* Comments here */
You can edit or delete them by editing the line directly below the comment, and then clicking the cog wheel
