That piston worked for months and strangely it stopped working when I did 0 changes
An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
Do you have a copy of the piston? Do you know which part of the piston triggered that error?
It’s a simple piston that says if the switch is on then turn 2 lights off
And then turn the switch off
Again, you may want to post an image of the piston and logs. That way, we can better examine and hopefully provide you with some feedback. Right now, we basically do not have enough info to offer any insight into your situation.
