How to revert back to older Webcore version?
My question is simple. How to you revert back to an older version of WebCore in either Groovy or GitHub? I upgraded WebCore about a week ago and I am having issues with pistons. Light switches that I have pistons controlling will immediately come on after turning them off. Simple ‘lights on or off at sunrise/sunset’ are not working, and other issues I have to assume the version I just installed is creating the issues as it’s the only change.
The build currently active is v0.3.110.20191009
Thanks!
I suspect that Samsung made some changes to the base code recently… Time based triggers (including long WAITS) are not reliable at the moment…
Also, with today being a time change, there may be some pistons an hour off today…
Thanks. All pistons impacted are time based so this would make sense. They were incorrectly invoking prior to time change so I assume it was not an impact, or I’ll see higher impact starting today.
