How to update of the WebCoRE IDE?
The dashboard has been prompting me to update the WebCoRE code. So I attempted to do so. I went into the SmartThings IDE, in the My SmartApps tab, did an “Update from Repo” on for all four of the WebCoRE code blocks. That seems to progress properly, however, I had not noticed the “Publish” check box when I was doing it. The update change didn’t take place. Was not checking the Public checkbox why it did not take effect?
Is there a fix?
Thanks in advance
Cheers,
Ray
Hi Ray,
It never happened to me (was lucky enough to never forget the checkbox, which is surprising TBH) so my advices might not be 100 % accurate.
I know hovever that you can click on each smartapps and a “publish” button will be presented to you. Choose “publish for me” which is usually the only option and the updated version will be published.
Hope this help. If you need more in depth advice, I probably can provide screenshots.
Thanks for the help and quick response. I did it and all are now marked as published.
I thought that I attempted to do this the other day but the PUBLISH button did not present itself. Whatever, I did what you suggested and it worked. Thanks
Cheers,
Ray
