HSL colour setting not working as planned
I am trying to set a custom colour on my light based on what i see in the IDE ( i set mine in the hue app and then refresh the device in IDE) and then set in WC.
However when set the piston triggers but set the HSL to a different outcome based on what i see in the IDE.
This is what i input . Should i be not just copying what i see in the IDE?
L should be 54?
I agree with @eibyer. This line should do what you want:
temp
(levels should always be between 1-100)
You might have already discovered this, but for the benefit of others reading this thread:
The IDE returns level, hue, saturation, color, and colorTemp… However with Philips Hue, whenever we want to USE those numbers, it is important to only use Hue, Saturation and Level.
(It is counter-intuitive, but if you are matching colors, do not use color or colorTemp)
For future reference, this is the piston I use to gather the current color of a bulb so I can recall those HSL numbers anytime in the future:
This gives me the info I need in one click, instead of poking around in the IDE…
Can't figure out how to change color "Lightness" in webCoRE with Hue lightstrip
Adding to this
If I enter the following into the evaluator:
{hslToHex(0,100,50)} »»» (string) #800000
That result is wrong
according to several online calculators, the answer should be #FF0000
yup, its clearly broke in the conversions.
I threw some of the methods from this in and it now it returns the proper values:
https://www.w3schools.com/lib/w3color.js
