So, I recently migrated my webCORE set up from ST to Hubitat. The process proved to be quite a pain. I had first migrated all my automations to webCORE in order to help facilitate the migration process, but I still ran into numerous issues.
In the end I migrated about 70 pistons and about 150 devices (physical & virtual). I have worked out all the compatibility issues & errors I saw in the logs, but now I am running into some performance issues with Hubitat.
After rebooting, Hubitat will perform decently for a period of time. But as time goes on, Hubitat will respond slower and slower, to the point of becoming unusable. Eventually, the Zigbee radio will give out requiring a reboot.
It seems that my Hubitat’s resources are getting maxed out, I guess this would explain the Zigbee radio drop.
In response, I have optimized most of my pistons. I also noticed that disabling recovery improved performance, at a cost.
So my questions are, is this common? Is there a work around?
This is getting to be a bit frustrating. I moved to this platform expecting faster performance and consistency due to local processing. But right now, this setup is so much worst than ST, it makes me long for the days when a piston would execute within 5 seconds.
