Ok, I live up in North East Pennsylvania and its #@#$! cold outside - and drier than is good in the house (sensors are reporting 15-20%) so I am on the hunt for a large room humidifier (preferably warm mist, but not picky) that either is ‘set and forget’ so I can use ST/WC with an appliance plug or better would be one that has ZWave compatibility built in.
Functional option:
Large room humidifier that I can set the humidity to say 90% and when the power comes on via a plugin module it turns on… use WC to manage the humidity (when sensor says < X% turn on when >Y% turn off. Not having a hellovalota luck finding any that meet this criteria (turning on to last setting for example) and hoping someone else has come across a solution.
I looked around here and the ST forums, seems that Holmes used to have one for WeMo (no longer available on their site)
Eventually I will install a humidifier into my HVAC but that is a project for another tax return …
