After creating the piston below with a ‘while loop’ the device will not shut off possibly due to all the delay commands
The piston behaves as expected to say that it takes a philips hue bulb and randomly adjusts the dim very rapidly and randomly to mimic a candle flickering effect.
I can no longer turn off the device because I think it is still trying to continue to execute the loop prior to receiving the off command.
The goal is to run the loop when the device is on and to be able to successfully shut the device off.
(UPLOAD YOUR IMAGE HERE)
