I spent three hours trying to create 1st piston...stumped
webCoRE says my piston won’t operation…I’m new to webCoRE, have no programming knowledge, and i’m struggling to create a simple piston. If somebody could please steer me in the right direction it would be greatly appreciated.
I want the holiday lights to turn on 20 minutes before sunset, and off at midnight
When i save the piston i get this response:
“This piston does not subscribe to any events. Unless executed by other means, it will never run on its own.”
5) Attach any logs
No logs, i can’t figure out how to get my first piston going.
Instead of using $time from the Variable option, try using Virtual device where Time will be an available option, then you can set your desired time of day with offset available below it.
Thank you so much! Could you possibly shed some light as to what the issue was so I know for future?
You had the correct idea, the only thing that messed up your piston is you inadvertently subscribed to the wrong trigger. Speaking of trigger, check out the link below for a good read on triggers and conditions.
